Aftermarket chrome meter covers
05 Apr 2019 13:42 - 05 Apr 2019 13:43
Z1Enterprises lists some chrome meter covers with clamps that fit various 70s KZ models >>
Z1Ent >> Gauge Covers
Do the covers & clamps fit over the stock meter housings & crimp rings?
Last edit: 05 Apr 2019 13:43 by martin_csr.
Re: Aftermarket chrome meter covers
05 Apr 2019 13:45
Yes but I don't now about yours.
05 Apr 2019 13:57 - 05 Apr 2019 14:29
Do you have any idea how much larger they are than the stock 70s crimp rings?
I was thinking I might be able to use the clamps on my meters in place of the rings.
The 81 650-CSR crimp rings are 112mm OD & the earlier 650s are about 104mm OD >> so wondering what the clamp OD might be?
Last edit: 05 Apr 2019 14:29 by martin_csr.
- 9er rider
- Keep a cool tool
05 Apr 2019 15:42
Z1 replies "What EV" on fitment what you see is what you get,, kindof
05 Apr 2019 15:48
The early KZ 650 tach is identical to the Z1 in size. I used the guts in mine. Those chrome covers will work on them. Yours are larger so I doubt they will fit on yours.
05 Apr 2019 16:53 - 06 Apr 2019 07:45
Thanks. I just want to try the clamps, not the chrome covers >> I know the covers won't fit.
I'm thinking if the clamps fit over the Z1 crimp rings & chrome covers, then they might fit the csr meter housing assy if I don't use the crimp ring. Mine are 112 mm OD & the Z1 crimp rings should be about 104mm. I'm thinking the aftermarket clamps would be in the 108 to 112 mm range & I'm guessing they have some flex to them.
Last edit: 06 Apr 2019 07:45 by martin_csr.
05 Apr 2019 17:43
I never liked the look of the clamps. If I were to get some I'd silicon them on without the clamps if I could.
