Fusing for best result
- Trackerkz650sr
- Banned
27 Mar 2019 11:20
Simple question
I simplified my harness/made one
Im running igntion off one fuse
And all my lights off another
Is that fine to do?
I know stock had a headlight fuse and tail light fuse seperate
Guessing for
I am running all led lighting and a 20 amp switch
Is that fine to do?
Guessing for
Re: Fusing for best result
27 Mar 2019 12:46
Z1's have one fuse for the entire bike.
- jayrodoh
27 Mar 2019 18:52
One fuse for all your lights is fine from an electrical perspective. The most reasonable explanation I’ve heard for separate is you wouldn’t want your tail light to go out should something happen to your turn signal system that causes the fuse to blow.
1982 KZ750-M1 CSR
27 Mar 2019 19:00jayrodoh wrote: One fuse for all your lights is fine from an electrical perspective. The most reasonable explanation I’ve heard for separate is you wouldn’t want your tail light to go out should something happen to your turn signal system that causes the fuse to blow.
True. Also, you REALLY would not want your headlight to go dark while you're riding at night on a dark, curvy road! (guess how I know). So since you are setting up your own fuse configuration you may want to consider running the headlight on its own dedicated fuse. Ed
