Incorporating Dyna S on KZ1100
Re: Incorporating Dyna S on KZ1100
17 Mar 2019 18:10
Yes.
- loudhvx
17 Mar 2019 20:11 - 23 Mar 2019 09:02
The dyna s does not have have electronically adjusted timing advance as the dyna 2000 does. The advance is varied mechanically same as points or the kz electronic ignition from the factory, so the dyna s requires a mechanical advance unit (which the bike should already have).
I'm not sure if the dyna 2000 gets the rotor set at full advance or idle position. The kz ignition and dyna s get their overall timing position set by the mechanical position of the timing plate. The same is likely true of the dyna 2000.
Link to related thread:
www.kzrider.com/forum/4-electrical/61023...ng-out-kz1100#800893
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 23 Mar 2019 09:02 by loudhvx.
- DOHC
- Those Doe-Hawks really go!
18 Mar 2019 06:42loudhvx wrote: I'm not sure if the dyna 2000 gets the rotor set at full advance or idle position.
The Dyna 2000 trigger replaces the entire mechanical advancer assembly with a fixed rotor.
www.z1enterprises.com/dyna-2000-billet-rotor-w-1-magnet.html
'78 Z1-R in blue
, '78 Z1-R in black,
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
- daveo
18 Mar 2019 08:16 - 18 Mar 2019 08:22
I recently used a timing light with engine revs around 3500, and set the timing at 40 degrees per FSM specification.
Ignition timing can also be set manually by turning the crank clockwise with a 17mm wrench (with spark plugs removed), and stopping when the Dynatek 2000 module light comes on at the correct degree mark, which is governed by position of the back-plate. The key needs to be on during this process, so I pull the headlight fuse when doing it this way.
I prefer the timing light method.
1982 KZ1100-A2
Last edit: 18 Mar 2019 08:22 by daveo.
