One turn signal not flashing on kz
- Bulletkz
28 Feb 2019 15:31
Trying to troubleshoot a turn signal problem with my 80 kz1000 .
the right front turn signal refuses to flash , it just stays light.
All the other signals work fine.
I checked everything, all the light bulbs, grounds, replace the flasher with a few different ones and still no luck.
Any ideas?
Any ideas?
Re: One turn signal not flashing on kz
28 Feb 2019 17:52
Bad ground?
28 Feb 2019 18:42
The wayward signal is seeing power all the time. That's not how it should work. Power should only flow when the flasher activates. I think you should check to make sure the wire from the signal is joined to the correct wire on the harness.
I have a B4, but wiring for the signals is a bit different because they are on the bars instead of attached to the headlight shell.
- sharkmonkey
06 Apr 2019 02:48
Just checking to see if this was resolved.
I have an 83 KZ750 twin and the right turn signal stays on as well. The rear light is on while the front light goes off. The left side works fine. I have swapped the bulbs as well.
-Mark
-Mark
1983 Kawasaki KZ750 KZ1 LTD (belt)
1980 Honda CM400T
1980 Honda CM400T
- Bulletkz
17 Aug 2019 17:15
Fixed it. Turned out someone cut and spliced the wires wrong in the headlight and ran out the correct color wires.
Some people should not touch wiring.
