Hi, I had an issue to install fog lights finding a wire running to the front of the bike. Used a white/blue wire from hazard lights (not present anymore) to do the trick. This was another issue posted which looks like I found a solution. After resolving it, for my surprise the front brake - brake tail light stopped working. The rear brake - brake tail light works properly. All connectors and wires look in the right place and the 2 wires coming out of the front brake have continuity to the relay and blue wire going to the tail light. Even after checking everything can't figure out what's wrong. I checked if I cut something, something disconnected, some short, fuse etc but all looks ok. If someone have an idea of the issue please let me know. Thanks!
UPDATE: I was able to locate the problem. One of the connectors, I believe original one with 9 pin and in fact 8 wires on my had the Green/White wire cut, I guess not on purpose but got cut. So if anyone ever had a front brake - brake tail light not working checking this wire on the pin may be one of the ways to start.
