Horn circuit kz1000 J3 83
- MartyZ1000
13 Feb 2019 10:27
So I have two functioning horns and a button doing Nothing. My wiring is slightly modified just as bike but all Basic functions and wiring/color cables the same.
Is there a relay involved? What type of circuit do the horns run on, plus/minus on/off or current on and earth added? I have some kind of unconnected relay behind the battery with three pins.
When I bridge the button contact Nothing happens so have to start measuring...
Re: Horn circuit kz1000 J3 83
13 Feb 2019 20:39
The horn button completes the ground to the horn. Power comes from the brown wire.
The following user(s) said Thank You: MartyZ1000
- MartyZ1000
13 Feb 2019 21:26SWest wrote: The horn button completes the ground to the horn. Power comes from the brown wire.
Great thanks Steve then it´s just good ole measuring time!
14 Feb 2019 06:21
I added a second horn (LOUD) with a relay to my KZ650-C1 while keeping the original horn and the original wiring. Below is the diagram I made to document the change, it may be helpful. Ed
- MartyZ1000
14 Feb 2019 06:43Cool so now you have a three part harmony! I'm thinking of switching to something more powerful too. My originals have 12V
and sound a bit when grounded but its not much so some more Dbs is definitely on the table...
14 Feb 2019 06:56
I have duel horns I got at HF. The relay is powered by the horn circuit and the horns get their power from the harness. Ground from the frame.
14 Feb 2019 07:52MartyZ1000 wrote: Cool so now you have a three part harmony! I'm thinking of switching to something more powerful too. My originals have 12V
The horn I added is a FIAMM 72112 Freeway Blaster Horn (Low Tone - F). It's tucked up near the steering stem, so it is not visible with the fuel tank in place. Below is a comparison of the stock horn vs. both horns. Ed
Attachment FiammHorn_2019-02-14.mov not found
14 Feb 2019 19:50 - 14 Feb 2019 19:55
I'm happy with these.
Last edit: 14 Feb 2019 19:55 by SWest.
14 Feb 2019 20:15
Steve, holy cow, that's loud! Maybe I should get one like the one in the video below. :woohoo: Ed
14 Feb 2019 20:23
:lol: :lol: :lol: I think he'll have to wipe.
- Olajoe
- Free at last
16 Feb 2019 07:00SWest wrote: I'm happy with these.
Stock charging system, stock battery?
16 Feb 2019 07:04 - 16 Feb 2019 07:06
YUP. The relay takes the power directly from the battery for the horns. Not bad for less than $10.
Last edit: 16 Feb 2019 07:06 by SWest.
