How to wire aftermarket speedometer tachometer.
  • 80kzer
  • 80kzer's Avatar
Re: How to wire aftermarket speedometer tachometer.
10 Jan 2019 16:29
#796498
Here is the wiring diagram I made to make it plug and play, please excuse the sloppy writing. I have noticed those speedos sometimes have different coloring wiring, hopefully yours is the same.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
11 Jan 2019 02:15 - 11 Jan 2019 02:15
#796513
For the 9 pin connector looks like this:
right directional
high beam
lights
left directional
tach
negative
fuel sender if equipped
acc ON positive
GR harness if for a gear indicator
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
Last edit: 11 Jan 2019 02:15 by Kidkawie.
  • JohnLuke
  • JohnLuke's Avatar Topic Author
  • 1982 KZ750N Spectre
11 Jan 2019 07:09
#796518
Thanks man! That looks great.
Actually I have everything working well on the speedometer side. I’m just having little trouble getting the tachometer to work. I’ll do another look through to see what’s up.
Thanks!
  • sdk_spider
  • sdk_spider's Avatar
17 Jan 2019 06:51
#796930
any luck with the tacho, I am having the same issue getting it to work on my 84 GPZ550
  • Tdogg1226
  • Tdogg1226's Avatar
06 Mar 2020 21:32
#820451
Yo, looking for how you got your wiring to work with that gauge. I have nothing worth the wiring schematic to my 82 KZ 1000 LTD cop edition and nothing works except the damn headlight regular light and bright indicator on this pos gauge. Please help!
  • JohnLuke
25 Mar 2020 16:01
#821744
I ended up trashing it and going with a dime city cycles mini speedometer. Totally worth the money very happy with it.
