KZ750-K1 Twin No Spark
- DoctoRot
Re: KZ750-K1 Twin No Spark
12 Dec 2018 20:52
if the previous owner ran 10w30 long term that could have done engine damage for sure.
- journeyman846
12 Dec 2018 21:20
I don't think the previous owner ever had it running well enough to ride. The last registration was 2016 and he never even transferred the title into his name.
1983 KZ750-K1
- DoctoRot
13 Dec 2018 09:28
I think Scirocco is probably right. i would check your valve clearance and if that isn't crazy far out i would tear it down.
- journeyman846
13 Dec 2018 12:47
So 3 out of 4 were way off. Exhaust Valves were at .127mm and .178 mm and Intake were at .063 and something smaller than .038 (the smallest gauge I had). So I guess it would be worth adjusting these before tearing into the bottom?
1983 KZ750-K1
13 Dec 2018 13:30 - 13 Dec 2018 23:55
Don“t waste your time with the valve adjustment, go tearing into the bottom.
www.z750twin.de/index.htm
(click on the english page button)
It is a helpfull resource for your tear down.
Last edit: 13 Dec 2018 23:55 by Scirocco.
- journeyman846
13 Dec 2018 18:02
Ok, just because I'm hunting for any reason not to tear into the bottom end ( mostly cause I'm not sure it's worth the effort) would the camshafts being out of time cause this noise? With the crankshaft at TDC the intake cam is lined up, but the exhaust cam is one notch off.
1983 KZ750-K1
- DoctoRot
15 Dec 2018 14:21 - 15 Dec 2018 14:23
doubtful. if its knocking hard its probably tear down time. I have a bunch of extra parts if you need anything like a crank or whatever
Last edit: 15 Dec 2018 14:23 by DoctoRot.
- DoctoRot
15 Dec 2018 14:33
did it sound this bad when you first got it running?
- journeyman846
15 Dec 2018 14:48
It had a massive exhaust leak so it was hard to tell. But yes, it's always sounded off. I found a video on YouTube of a quick way to check rod bearing slack by pushing the piston down slightly on the downward stroke. The right piston didn't move but the left moved noticeably, probably almost 1/4 of an inch.
1983 KZ750-K1
- journeyman846
16 Dec 2018 12:51
Yup, as i anticipated before. Crank and rod(s) are shot.
- DoctoRot
16 Dec 2018 13:41
bummer man. If you choose to rebuild the engine I have a crank that you can have for shipping.
