Dina pickup power wire
- bergerbut
22 Nov 2018 06:20
my plan is to pull power from a coil terminal for the dyna electronic ignition . personally i dont like the pinch / piggy back conecters, advice welcome
Re: Dina pickup power wire
22 Nov 2018 07:17
I soldered a male bullet connector on the red wire so I could plug in into the red/yellow connector. That way I can go back to stock coils just in case the Dyna coils fail. I also have a relay for the coils so the system isn't taxed as much. The Dyna S and 3 ohm coils use a lot of power.
22 Nov 2018 10:21
Some motorcycle models have an available switched battery positive female bullet fitting which can be used for an accessory, as does my KZ900LTD which is used to power the Dyna-S.
- Move0ver
22 Nov 2018 11:57Patton wrote:
Somehow the previous owner of my Z used the metal spacer with dyna coils with no issue... when I replaced the dyna coils with a new pair, I was unable to replicate his success and wound up using heatshrink wrap over the metal spacer.
Genius idea using nylon spacers!
22 Nov 2018 13:47 - 22 Nov 2018 13:56
The metal spacers help to dissipate heat. I wrapped mine with tape.
Last edit: 22 Nov 2018 13:56 by SWest.
- gordone
22 Nov 2018 14:02
Hemm... I have metal spacer on mine and have not had problems.. I know about
heh
Project:
Project:
22 Nov 2018 14:06
The positive screw can short on the spacer. I used button head screws but still there wasn't a lot of gap thus the tape.
- bergerbut
- z1kzonly
23 Nov 2018 06:52
The stem on these DYNA coils must have gotten hot enough to soften the epoxy holding them inside coil. I can slide the stem back and forth.
I used these 20 yrs. ago on a car tire bike.
And DYNA pick ups do blow out with high rev & heat. Got a pile of juck!
But for mounting, this gray stuff on frame & green coils is 3/8" plumbing sink supply hose. works perfect $1.99 for a 12" piece.
Or you can always make a longer bracket, so you use the farther hole away from screws.
- bergerbut
23 Nov 2018 12:37
nice;;; i used JEGS vacuum caps ;; gave it a nice look;;
- gordone
23 Nov 2018 17:13
I found some picture from my coils, I dont`t think it shall be any problem here?
Looks like I have another angel on the coils towards the frame....
Project:
Project:
