Dina pickup power wire
- bergerbut
Re: Dina pickup power wire
03 Apr 2019 12:09
Found a wiring diagrams for installation ;; dyna;;;
it matches my plan to pull power from a coil;;;
03 Apr 2019 13:02 - 03 Apr 2019 13:02
Remember to check for an available un-used female bullet connector fitting on a brown wire somewhere from the harness, which may avoid any splicing by providing a quick clean connection for a male bullet on the wire that feeds battery positive voltage to the Dyna-S (such as on the '76 KZ900-B LTD). The factory wiring diagram should show any extra un-used brown wire female bullet connector that's available in the stock wiring.
Last edit: 03 Apr 2019 13:02 by Patton.
The following user(s) said Thank You: bergerbut
- loudhvx
03 Apr 2019 13:42 - 03 Apr 2019 13:45
There are a few iterations of the Dyna S (small KZ's versus big Kz's) . This animation shows the minor differences in the wiring... mostly wire color and "tube" color.
www.kzrider.com/media/kunena/attachments/959/DynaSwiringANI.gif
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 03 Apr 2019 13:45 by loudhvx.
03 Apr 2019 14:17
I would not take power from a coil. I do what Patton suggested. I use the brown wire on the headlight end of my wiring harness.
