What to consider before buying aftermarket speedo / tach
- jCabla
19 Jul 2018 18:20
Hi everyone, I recently bought a 1978 KZ400A and stripped it down and am slowly putting it back together, i am working on my handle bars right now and my old tach and speedo are pretty beat up. I see there are some electric ones that are a little pricey but i wouldn't mind putting one on. Has anyone ever put a newer speedo on an older bike? Any advice on what to look for when picking one out? Splicing, etc?
PS this is my first motorcycle so i am not super educated haha!
Thanks!
Thanks!
- gordone
Re: What to consider before buying aftermarket speedo / tach
20 Jul 2018 03:54
Follow
Project:
Project:
- Warren3200gt
20 Jul 2018 12:17
Don't know your model bike but from the year I suspect your rev counter will be cable driven from the cam shaft and the worm drive will need to be blocked off to stop oil pouring out the cam cover when the engine is running. A new one will be electronically driven and will need wiring in. Does your bike have points or electronic ignition?
- gordone
20 Jul 2018 14:10
When it comes to rpm, I have seen eletrical one often sense on the eletrical power to the coil to pick up the pulses to calculate actual rpm.
For the speed I have seen proximity swith has been installed to detect speed on the wheel.
Project:
Project:
- Warren3200gt
20 Jul 2018 14:19
Your right that is how they work, however pulses from points ignition are often much more powerful and eratic in wave length than pulses from electronic ignition and you need to ensure the rev counter you buy has a chip in it capable of handling points output. thats if you have points of course. A counter capable of points will work with either ignition, a counter only capable of electronic will blow the chip fairly quickly if used with points.
- DoctoRot
20 Jul 2018 21:16
There are small mechanical gauges available, those are probably the cheapest and easiest swap, however all the ones I have seen are not the best quality. There are speedos with magnetic pickups to determine wheel speed. Or if you want to get fancy Speedhut has GPS speedos, which is what I run on both my KZ's. Like Warren said you will need a tach plug if you go electronic tach. BTW swapping to electronic ignition is always a good idea IMHO, less fuss.
- gordone
21 Jul 2018 00:35DoctoRot wrote: There are small mechanical gauges available, those are probably the cheapest and easiest swap, however all the ones I have seen are not the best quality. There are speedos with magnetic pickups to determine wheel speed. Or if you want to get fancy Speedhut has GPS speedos, which is what I run on both my KZ's. Like Warren said you will need a tach plug if you go electronic tach. BTW swapping to electronic ignition is always a good idea IMHO, less fuss.
Could please post what GPS type you have / reccomend?
What about instrument include speed and tacho, with GPS and elec. Tacho of good quality?
Project:
Project:
- DoctoRot
21 Jul 2018 02:19 - 21 Jul 2018 02:28
I'M using speedhut gauges on both my bikes. They seem pretty good so far. but I had issues with the tach and the the Dyna s ignition on my kz1000, i had to reroute the wires away from my coils and get a noise reducer for the tach. My kz750 is using a C5 ignition and i had no trouble there. The GPS is pretty cool but its sensitive to loosing signal, if i drive under an overpass the needle will drop.
Speed hut gauges are not made for motorcycles. They are not water proof, but resistant. However they also have a lifetime warranty. They can put a bead of silicon around the glass but you will need to make some type of cover for the back to protect the gauge.
The gauges are also very customizable. I designed custom faces and had them make them for me.
Last edit: 21 Jul 2018 02:28 by DoctoRot.
The following user(s) said Thank You: gordone, Wafflez
- gordone
21 Jul 2018 11:08
Other who has experience with eletrical speed and tacho built into one instrument for motorcycle use?
Project:
Project:
- Bama704
31 Mar 2020 06:30
I know this is an old thread, but I just bought a speedhut gauge speedo/tach combo and am pretty excited to get it. Will post up some pictures when I get it installed and wired up. I asked them if there would be a problem with having points ignition, and they said there was no issue with their gauges and points. However they are including a tach filter just in case, which I will put on when wiring up.
1977 KZ900
Carbs are late model 1975 28mm
The following user(s) said Thank You: martin_csr, gordone
- gordone
31 Mar 2020 06:34
Looking forward for updates!
Project:
Project:
- 750 R1
04 Apr 2020 14:49gordone wrote: Looking forward for updates!
gordone PM sent mate...
