- Thank you received: 1616
Ic ignitor in my kzp
- loudhvx
16 Jun 2018 16:03 - 16 Jun 2018 16:08 #785284
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Ic ignitor in my kzp
Timing is not meant to be adjustable, and will not cause an igniter to burn up.
I see they went to a different igniter type, but since the pickups are the same I assume the igniter works pretty much the same as the older type.
You can make a new one easily and cheaply if you can get right type of HEI module:
s3.amazonaws.com/gpzweb/Ignition/GPZgmHEImod.html
1981 KZ550 D1 gpz.
Other links.
Last edit: 16 Jun 2018 16:08 by loudhvx.
The following user(s) said Thank You: KZP1000
- KZP1000
21 Jun 2018 05:28 #785557
by KZP1000
Replied by KZP1000 on topic Ic ignitor in my kzp
Thank you I'll check the voltage today.
