Are the two pickups on a Dyna S identical?
  • aenikolopov
  • aenikolopov's Avatar Topic Author
19 May 2018 17:21 - 19 May 2018 17:22
#783695
So, I think I blew out my electronic ignition, or rather I think I blew out half of it. This is a 1980 KZ650F1. Working on it, I accidentally switched the spark plug wires for 3 and 4. Starting it up, the 20Amp fuse blew, and when I replaced it and started things up, only cylinders 1 and 4 were firing. I've tested the 2/3 coil and it's fine (it fires 1/4 fine if I hook it up to those), and the wiring from the Dyna S to the coils seems fine. Externally, the dyna seems fine, but there looks to be a tiny bit of melted insulation near the the pickup that leads to the 2/3 coil, and that makes me think that it shorted out and burned up.
To test my theory, I'd like to switch the two pickups on the Dyna S (this is a DS2-2), to see if that switches which cylinders fire. Anyone know if they are identical??
As an aside - does anyone know if Dyna sells replacement pickups, or do I have to replace the whole unit, if I choose to do that
Last edit: 19 May 2018 17:22 by aenikolopov.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Are the two pickups on a Dyna S identical?
19 May 2018 17:32
#783697
You can call them and get what you need. Good people.
The following user(s) said Thank You: aenikolopov
  • aenikolopov
19 May 2018 17:37
#783698
That's good to hear, thanks. Will give them a ring Monday.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
19 May 2018 17:40 - 19 May 2018 17:40
#783699
I do´t think you got the pickup´s separately.
You have to buy the complete pickup plate if available as a spare part.
Both pickup´s get the voltage with the red wire so why should they burn or melded by swapping the spark plug wires???
A pic would help to diagnosing you problem.
Last edit: 19 May 2018 17:40 by Scirocco.
  • aenikolopov
19 May 2018 17:42
#783700
Scirocco wrote: I do´t think you got the pickup´s separately.
That's a strong point, I'm not really sure. A pic of what would help? the melted bit?
  • SWest
  • SWest's Avatar
  • 10 22 2014
19 May 2018 18:17 - 19 May 2018 18:25
#783704
I doubt switching wires would do it. They do sell parts separately. I bought a rotor last year $25. Had it in three days. You can turn the rotor 180* to test. I'd call and ask.
Closed mouths don't get fed.
www.dynaonline.com/products/sportbikes/dyna-s.aspx
Last edit: 19 May 2018 18:25 by SWest.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
19 May 2018 18:31 - 19 May 2018 18:36
#783706
The pickups are on the primary wiring side of the spark coil.
The spark plug wires are on the secondary wiring side of the spark coil.
They a not direct electrical connected, only by inductive electric fields
You have to do a shortcut test with a multimeter.
P.S
My first 1000th post, more to come....
Last edit: 19 May 2018 18:36 by Scirocco.
  • loudhvx
  • loudhvx's Avatar
19 May 2018 19:19
#783709
If it does turn out to be one of the units is bad, like Steve said, they will usually sell you just that part.
The pickups/driver units are pretty sensitive, and it is not uncommon for one to go belly up. Luckily Dyna has been good about customer service.
  • aenikolopov
19 May 2018 19:27
#783710
Scirocco wrote: The pickups are on the primary wiring side of the spark coil.
P.S
Hah, congrats on #1000.
You're right, I don't have a very good explanation of what happened. that said, the pickup does seem to be burned out. Testing for a short won't really answer the question as it's an issue of the electronics being burned out, which doesn't require a still-existing short.
  • SWest
  • SWest's Avatar
  • 10 22 2014
19 May 2018 19:32
#783711
Like I said, you can turn the rotor on the spark advance then switch the wires to the coil to see it the issue follows the change.
  • zed1015
  • zed1015's Avatar
20 May 2018 02:58
#783715
Switching plug wires wouldn't have done any damage to anything except fire the wrong plugs.
Both pick-ups are the same but "handed".
A good indicator of a faulty one is white contact paste creeping out from the back between the pick-up and back plate due to overheating as well as possible visible heat damage to the wire insulation.
Replacement pick-ups are simply soldered to your original wires with a bit of heat shrink to cover the joint..
Testing a bad pick-up is as mentioned usually a simple case of switching the the wires to the coils and turning the rotor 180 degrees and if the fault moves to 1-4 it's the likely to be the pick-up or associated LT wiring to the coils.
  • aenikolopov
20 May 2018 12:16
#783730
SWest wrote: Like I said, you can turn the rotor on the spark advance then switch the wires to the coil to see it the issue follows the change.
zed1015 wrote: Testing a bad pick-up is as mentioned usually a simple case of switching the the wires to the coils and turning the rotor 180 degrees and if the fault moves to 1-4 it's the likely to be the pick-up or associated LT wiring to the coils.
Right, right - I had thought I need to remove the pickups individually but I realize now that's unnecessary. You've both mentioned turning the rotor, but if I remember correctly, the rotor (the round black magnetic bit that fits over the shaft and advance mechanism) can only go on one way, so I assume you mean to install the entire plate inverted 180degrees (and reverse the wiring). That makes perfect sense, thanks!
