Function of the starter switch spring?
  • kzsolo
  • kzsolo's Avatar Topic Author
01 Apr 2018 13:35
#781110
I understand the button return function of the spring. But does it also create a connection between power and ground? Mine was broken so I replaced it with a cylindrical spring instead of the stock conical style. The starter works if I jumper it at the plug connection and the headlight switch at the handlebar pod works. If true, any idea where I can find the stock spring? Many thanks!
  • loudhvx
  • loudhvx's Avatar
Re: Function of the starter switch spring?
01 Apr 2018 19:54 - 01 Apr 2018 19:56
#781124
It might help to know what bike.
On most/all KZ's the starter button does NOT connect to ground.
But the horn button is similar, and it does connect to ground.
www.z1enterprises.com/yamaha-xs650-butto...-oem-27010-1009.html
Last edit: 01 Apr 2018 19:56 by loudhvx.
  • Irish Yobbo
  • Irish Yobbo's Avatar
02 Apr 2018 00:29 - 02 Apr 2018 00:29
#781128
Some bikes (my 1981 KZ750 included) use what is also used as a horn button as the starter button. And you are correct - the conical spring provides the connection from the base plate of the button to the button itself, and pressing the button closes the circuit.
The spring comes with the button (the same one that loudhvx linked).
1981 KZ750 LTD
Last edit: 02 Apr 2018 00:29 by Irish Yobbo.
  • TexasKZ
  • TexasKZ's Avatar
02 Apr 2018 05:05
#781138
A quick look at the wiring diagram for your year and model should answer the question.
  • kzsolo
02 Apr 2018 07:55
#781145
'78 KZ Twin. You are correct it does not connect to ground, a check on the schematic confirmed that. Thanks for the link, it is exactly what I was looking for.
