Can you identify a couple of things on diagram?
- lgyee4
18 Nov 2017 14:07
2 stroke rider
TZ 250, TZR 250, RD 400, RZ 350, RZ 500, WR 200, KDX 200, Vespa ET2
And one 4 stroke: 1979 KZ1000ST
Re: Can you identify a couple of things on diagram?
18 Nov 2017 14:27 - 18 Nov 2017 14:35
What is at the red arrow? is that a ground ring?
Yes it is the ground ring.
What color is at the green arrow? Is it black?
No, it is gray.
On the wiring diagram should be a color code chart
No, it is gray.
Last edit: 18 Nov 2017 14:35 by Scirocco.
- lgyee4
18 Nov 2017 14:50
Thanks Scirocco
I got the image from this website. No color code chart.
Even worse I purchased a copied FSM that is in black and white! It's like being color blind
2 stroke rider
- Zeerx
18 Nov 2017 15:34
I could be wrong but i think that signifys where the wire is riveted to the ground washer for the turn signal inside the headlight shell.
‘78 KZ750B, ‘12 F150 (Ford)
