Wiring ?????
- Markovich
Wiring ?????
29 Sep 2017 15:42
Hey guys, still at it on the 1990 KZP. Right now I'm trying to figure out what I can delete without messing up something else. Working with the wiring diagram but don't know best way to isolate each thing. So, any help on how to get rid of the turn signal self cancelling control unit would be great. Also, I will try to show a component I can't seem to identify. Anyway, all advice and guidance would be appreciated. Thanks, Keith
1990 KZ1000P, 72k miles, 10 years in storage, new, bars, tires, chain and sprockets, seat, carbs cleaned, police equipement removed.
- Markovich
Re: Wiring ?????
29 Sep 2017 15:47
- Markovich
Re: Wiring ?????
29 Sep 2017 15:49
Re: Wiring ?????
29 Sep 2017 18:25 - 29 Sep 2017 18:29
From the Electrical equipment diagram at Partzilla that appears to be a relay of some sort. #45 in the drawing. there's a photo of it. I'm not 100% sure, though.
Last edit: 29 Sep 2017 18:29 by martin_csr.
The following user(s) said Thank You: Markovich
- loudhvx
Re: Wiring ?????
29 Sep 2017 20:03 - 29 Sep 2017 20:05
The blue splice is some later add-on by a user probably.
Can you tell what the other wire colors are? That might help narrow it down.
Because of the yellow wires, I first thought siren related. But not sure.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 29 Sep 2017 20:05 by loudhvx.
Re: Wiring ?????
29 Sep 2017 21:59 - 30 Sep 2017 00:09
It is a kind of power relay for police pursuit light or siren equipment (purple/yellow wires)
ND Nippon Denso 056700-3611 Relay
056700 5260 Relay 12V 22A For Toyota MR2 Hilux 4Runner-in Switches from Automobiles & Motorcycles
It is a power relay only, not a flasher relay
www.alibaba.com/product-detail/Auto-part...22A_60454663821.html
Can your upload your wiring diagram?
Last edit: 30 Sep 2017 00:09 by Scirocco.
Re: Wiring ?????
30 Sep 2017 04:13 - 30 Sep 2017 04:19
In the parts diagram there is a pursuit relay listed, so it's probably for the siren stuff. see electrical & siren diagrams.
Last edit: 30 Sep 2017 04:19 by martin_csr.
- old_kaw
Re: Wiring ?????
30 Sep 2017 07:39 - 30 Sep 2017 07:40Scirocco wrote: It is a kind of power relay for police pursuit light or siren equipment (purple/yellow wires)
Yep! In looking at the electrical markings, that's just a normally open (NO) relay. Pin 1 &2 are the coil, and pin 3&4 are the switched terminals.
1981 Kawasaki Kz1000K1
Last edit: 30 Sep 2017 07:40 by old_kaw.
- Markovich
Re: Wiring ?????
30 Sep 2017 11:24
There are 2 yellow wires a red one and a grey with a blue stripe. The jumper is on the red and one yellow. I know when the cops sometimes sell them they strip the siren, and pursuit stuff but who knows if that jumper was to bypass something else. Harder to figure out when it's chopped up like that.
- Markovich
Re: Wiring ?????
30 Sep 2017 11:31
- Markovich
Re: Wiring ?????
30 Sep 2017 11:34
I'm using a tablet so pictures are not the greatest. Also, note all the wires going to the turn signal self cancelling controller. Never worked since I got it. Ugh!
- Markovich
Re: Wiring ?????
30 Sep 2017 11:43
