What happened to my Dyna coils??
- whitskz
22 Aug 2017 19:21
Long story short, built bike 4 years ago, sold it, missed it, found it, bought it...back. guy barely rode it at all, not even 1000 miles, and now one of the green Dyna coils I got with the Dyna S ignition system has very weak spark, causing misfire. Motor is 78 kz1000. Both coils ohm at 3.1 or 3.2 and both are getting 12 volts. Did one just crap out? Seems like resistance would change once it was barely working or something. I ordered a new set but I still just wonder what happened?
- loudhvx
Re: What happened to my Dyna coils??
22 Aug 2017 20:21
He could have left the ignition turned on but motor not running. That has been known to melt coils with the Dyna S ignition system.
(That doesn't happen on the factory electronic ignition, but can happen with points.)
How do you know it's the coil and not the Dyna S ?
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- whitskz
22 Aug 2017 20:38
I swapped the coils and the misfire followed the coil. I have no idea how to troubleshoot the dyna s.
- loudhvx
23 Aug 2017 07:48That's exactly how.whitskz wrote: I swapped the coils and the misfire followed the coil. I have no idea how to troubleshoot the dyna s.
1981 KZ550 D1 gpz.
Other links.
Other links.
23 Aug 2017 07:58 - 23 Aug 2017 07:59
Be sure the power feed to the coils is switched on through the ignition switch and not hot all the time.
I've read about Dyna coils failing before, both here and on the GS Resourses. I'm not a hater but I don't think they are of the highest quality either.
Last edit: 23 Aug 2017 07:59 by Nessism.
23 Aug 2017 08:09
Check your H/T connections. Could be some corrosion at the coil or cap.
- whitskz
23 Aug 2017 08:25
No corrosion, switched 12v for sure. The wiring was a pain since I "needed" it all hidden in the neck gusset. I'm betting the key got left on, he has kids and I'm sure my boy will fiddle with the key at some point too. I guess I could take it out but then I'd lose it lol.
