'79 B3 Wiring Schematic
  • Mikaw
  • Mikaw's Avatar Topic Author
15 Jul 2017 20:40
#767050
Looking for a 79 LTD Wiring Diagram.
  • TwoCam
  • TwoCam's Avatar
Re: '79 B3 Wiring Schematic
16 Jul 2017 06:21
#767066
Kz1000?
  • loudhvx
  • loudhvx's Avatar
16 Jul 2017 10:15
#767079
There are several diagrams for a 1000 B3 in the filebase. Hover over "Filebase" and click on "Kz Documents". Follow the links till you get to Kz1000 electrical. There are 3 pages of diagrams. Page 1 has a colorized version.
  • Mikaw
16 Jul 2017 14:32
#767101
Yes a 1000.....1979 LTD "B3". I have looked thru the file-base and not the schematics i need. The only 79 in there is for a bike with breaker points, mine has pickup coils. Maybe its identified wrong or its an "A" and not a "B". The 1980 B4 in Chinese has the turn signal control unit which I don't have
  • TwoCam
  • TwoCam's Avatar
16 Jul 2017 14:59
#767102
Your correct.....'78 and up had factory electronics ignition.... voltage Reg and rectifier were one unit and no more head light switch unless euro..... after '78. I'm sure I have a diagram at the shop. I'll check tomorrow when I get to work. Most of the wiring is the same as the older bikes. The '78/79 had the MKII engine. Had a bigger crankshaft and different alternator. Still a 3 phase but totally different design.
  • Mikaw
16 Jul 2017 16:12
#767114
TwoCam.... Thank you but it needs to be a 79-80, My 78 LTD has points and separate regulator and rectifier. JUst found out I do need a reserve lighting unit.
  • TwoCam
  • TwoCam's Avatar
16 Jul 2017 16:49
#767119
Let me see what I have...... I'm going from memory...... i have 2 factory manuals. One for 77, other for 81-83 and an aftermarket manual......I know for a fact that '78/9 are mK II engines.... all by themselves for a lot of stuff...... stay tuned buddy......
  • TwoCam
  • TwoCam's Avatar
17 Jul 2017 04:47
#767143
  • TwoCam
  • TwoCam's Avatar
17 Jul 2017 04:48
#767144
  • TwoCam
  • TwoCam's Avatar
17 Jul 2017 04:50
#767145
  • TwoCam
  • TwoCam's Avatar
17 Jul 2017 04:50
#767146
  • TwoCam
  • TwoCam's Avatar
17 Jul 2017 04:51
#767147
