Ignition Timing
  • 76KZ900
  • 76KZ900's Avatar Topic Author
Ignition Timing
05 Jun 2017 13:04
#763623
I have looked through my service manual a dozen times and cannot find how to check timing with a light.. Am I looking for the "F" mark at idle ?
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
76KZ900 (sold) regret
03ZRX1200R (sold) regret
83KZ1100 LTD Shaft
Re: Ignition Timing
05 Jun 2017 14:01
#763628
There is nothing in the ignition to adjust on the 1983 KZ1100. Ed
  • 76KZ900
Re: Ignition Timing
05 Jun 2017 14:06
#763629
Uh yes there is... The timing can be adjusted.
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
Re: Ignition Timing
05 Jun 2017 14:24 - 05 Jun 2017 14:25
#763631
76KZ900 wrote: Uh yes there is... The timing can be adjusted.
Really? You may want to contact Kawasaki and tell them that the Kawasaki Service Manual for the KZ1100 is wrong. ;) Ed
Last edit: 05 Jun 2017 14:25 by 650ed.
  • 76KZ900
Re: Ignition Timing
05 Jun 2017 14:41
#763632
So if I remove the three screws and turn the ignition plate it isn't going to change the timing at all ?
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Ignition Timing
05 Jun 2017 15:03
#763636
Yes it will. There has to be an initial timing procedure to set it up.
Re: Ignition Timing
05 Jun 2017 15:12 - 05 Jun 2017 15:16
#763639
76KZ900 wrote: So if I remove the three screws and turn the ignition plate it isn't going to change the timing at all ?
How do you propose to fasten the plate to the engine if you remove the 3 screws and turn it? The holes in the ignition plate are round; they are not slots (see images below). Are we talking about the same bike in your signature line - a 1983 KZ1100 LTD? Ed
Last edit: 05 Jun 2017 15:16 by 650ed.
  • TexasKZ
  • TexasKZ's Avatar
Re: Ignition Timing
05 Jun 2017 15:22 - 05 Jun 2017 15:24
#763641
A little farther into the fsm, is the following. It can be checked, but not adjusted.
Last edit: 05 Jun 2017 15:24 by TexasKZ.
  • 76KZ900
Re: Ignition Timing
05 Jun 2017 15:27 - 05 Jun 2017 15:29
#763646
I got it. It was the "F" mark at idle. I removed the ignition housing to install new chrome one. So it had to be "set" Ed my timing plate is slotted and I didn't want to guess that middle of the adjustment slot was gong to be right. I understand that there is no reason to adjust it. But if you disassemble the whole thing, there has to be a check made
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
Last edit: 05 Jun 2017 15:29 by 76KZ900.
Re: Ignition Timing
05 Jun 2017 17:06
#763666
76KZ900 wrote: ..................Ed my timing plate is slotted and I didn't want to guess that middle of the adjustment slot was going to be right.........
Ah, that explains it. I guess someone replaced the non-slotted one at some point. Ed
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Ignition Timing
05 Jun 2017 17:33
#763669
Then it should be possible to use a timing light to set it at idle.
  • Tyrell Corp
  • Tyrell Corp's Avatar
Re: Ignition Timing
06 Jun 2017 06:16
#763710
Three marks : one is TDC for 1 and 4 and two for idle and advanced.
Strip and Lube the ATU with copperslip first , set the rotor /pickup gap evenly for both pick ups. Run at idle and use a strobe to rotate and line up the F mark. You should get full advance to the next mark at about 4000 rpm. Check the ATU is advancing smoothly,
