An electrifying story...
  • Skiprrdog
  • Skiprrdog's Avatar Topic Author
  • "Are we there yet?"
30 May 2017 09:12
#763093
Okay, so I finally got the 1983 KZ1100 running pretty good, and decided to save the best part for last. When I bought the bike, the PO told me it had a bad stator, that the battery was not getting charged. While running, a meter on the battery shows approximately 13.5 volts, and when revved up the reading will actually go down a little, not up. I checked the ohms on the stator and it looked okay. When I disconnected the three yellow leads behind the sprocket cover and checked there while running, I got 29 volts instead of the 50 VAC the manual called for. I thought, bad coils, so I got a replacement and put it in this weekend, and now I have 25 VAC at the three yellow wires... sooo, obviously the stator coils were not the problem. One thing I did notice when I was taking the alternator cover on/off that I was not fighting the magnet to get the cover on and aligned with the two pins, like I have on every other KZ I have worked on.
Is there a way to check the magnetism of that part of the alternator assembly, or not?
1983 KZ1100 A-3 Shaft
1976 KZ900
1975 H2 Triple
1984 Yamaha XJ900 Seca
1984 Harley Davidson FXRDG
#BlackBikesMatter
  • Tyrell Corp
  • Tyrell Corp's Avatar
Re: An electrifying story...
30 May 2017 09:33
#763094
"...One thing I did notice when I was taking the alternator cover on/off that I was not fighting the magnet to get the cover on and aligned with the two pins, like I have on every other KZ I have worked on."
Your problem is likely your rotor magnets, common problem on these. Getting quite a lot of vibration through the bars plus poor charging out put?
Be careful on differing crank nose tapers on the 1000j GPz1100 z1100 and zx1100 variants -they all look the same but there are two different part numbers..
The following user(s) said Thank You: Skiprrdog
  • Nessism
  • Nessism's Avatar
30 May 2017 10:10
#763098
Very odd results. You sure you had your meter set correctly, and that the meter works? Reason for asking is that it typically takes a lot more than 25 VAC to generate 13.5 VDC charging at the battery. I had a bike that made 75 VAC and it would only charge at 13.5. Those no load tests are not definitive in terms of defining a good stator.
  • SWest
  • SWest's Avatar
  • 10 22 2014
30 May 2017 10:22
#763099
New battery? What's the voltage after 24 hours of sitting.
  • Skiprrdog
30 May 2017 12:10
#763101
--Tyrell...no unusual vibration through the bars. The charging voltage while running seems okay, but even so, does not seem to be charging the battery.
--Nessism...Yes, they are odd results; meter set correctly, and I hear you on the no load part, but it is all I have right now!
--SWest...New gel battery... never checked the battery after sitting, will try that tomorrow. All I DO know right now is that I have to put the battery on a charger after only 5-10 minutes of running
1976 KZ900
1975 H2 Triple
#BlackBikesMatter
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Skiprrdog
30 May 2017 19:50
#763124
Well, I charged the battery; 13.16 volts.... will re-check in morning after sitting, Irrespective of the battery condition, the fact that I am getting only 25-29 VAC right at the alternator lends itself to only one conclusion, that the magnet is bad, I guess. Which sucks because all of the replacements I see are *crazy* expensive...she may have to sit a while...
1976 KZ900
1975 H2 Triple
#BlackBikesMatter
  • SWest
  • SWest's Avatar
  • 10 22 2014
30 May 2017 19:54
#763126
If it's putting out 13.5 volts, that's enough to run it.
  • RonKZ650
  • RonKZ650's Avatar
30 May 2017 20:38
#763133
Yea, the DC to the battery is all that matters. Reading AC on the stator leads to many false readings. I highly doubt the magnetism of the rotor being a problem. As Steve said, 13.5V on the battery it is charging to some extent, My 77 KZ650 only charges at about 12.7 volts due to the Dyna-S, but it charges and works good enough to ride.
The following user(s) said Thank You: SWest, Skiprrdog
  • SWest
  • SWest's Avatar
  • 10 22 2014
30 May 2017 20:53
#763134
I suspect I had a bad cel for over a year. I would only get 14.5 after miles of riding with the lights on. Now with the new battery, it goes up right away.
  • loudhvx
  • loudhvx's Avatar
31 May 2017 08:45 - 31 May 2017 08:46
#763155
Does the magnet seem solidly mounted? Maybe it is loose enough to spin? Is there a keyway on that model?
Also check to see if the stator and magnet fit together closely. Maybe someone put on a different rotor with a larger opening? This is highly unlikely, but would explain why it's so easy to pull the alternator cover off.
Last edit: 31 May 2017 08:46 by loudhvx.
  • Skiprrdog
31 May 2017 20:35 - 31 May 2017 20:36
#763209
Well, I charged the battery yesterday and then checked it today... went from 13.16 to 13.09. I would be tempted to switch out the magnet if I had one sitting around, and/or they were not like $200.00 for a new one, but I don't have one, so I am going to take everyone's advice and just button it back up and ride it for a bit and see what happens... just short/local trips, check the mail, etc., so I do not get stuck out somewhere.
Thanks to all of my esteemed fellow Kaw riders!
1976 KZ900
1975 H2 Triple
#BlackBikesMatter
Last edit: 31 May 2017 20:36 by Skiprrdog.
