  • Page:
  • 1
  • 2
Plugs Spark - Won't start 19 May 2017 15:38 #762237
  • ozone
  • ozone's Avatar Topic Author
  • Thank you received: 1
77 650 B1
It ran great when I took it apart. Did a frame up restoration. I can't get it to start.
Is it possible for the plugs to have spark but the points don't?
Since I have not been able to start it, I put it new points. Didn't fix it.
It's getting gas and the plugs are sparking.
Any ideas? Please help. Bummer.... all those hours and now I can't get it running.
Plugs Spark - Won't start 19 May 2017 15:41 #762238
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2635
Did you reverse the coil wires? I've done it.:blush:
Plugs Spark - Won't start 19 May 2017 15:53 #762240
  • JR
  • JR's Avatar
  • Thank you received: 435
SWest wrote: Did you reverse the coil wires? I've done it.:blush:
I've done that also. :) Couldnt figure it out and took the head off again and only when i was in the final steps of getting all back together did i realise i had the wrong coloured wire connected to the wrong coil.
Major DOH moment
Plugs Spark - Won't start 19 May 2017 16:48 #762242
  • Thank you received: 2829
When you "took it apart" did you remove, clean and re-install the timing advancer? If so, double check that when you re-installed it you oriented the advancer cam correctly. It can be installed in 2 different orientations, but only 1 of those orientations will fire the spark plugs correctly. If it is 180 degrees off the engine will not run no matter what else is done. The image below shows the correct orientation. Notice the little notch on the advancer cam needs to face the little hole in the advancer backplate. Ed
Last edit: by 650ed.
Plugs Spark - Won't start 19 May 2017 20:11 #762252
  • ozone
I did not take off the timing advancer, but I'll check that to verify it is correct. As for the coil wires. I mark them the coils left and right to make sure that were re-installed correctly. Also the coil wires have the original 1-2-3-4 stickers on them. They go left to right 1-2-3-4.
Correct?
Thanks.
Plugs Spark - Won't start 19 May 2017 20:13 #762253
  • ozone
Thanks. I'll double check the wiring to coils.
Plugs Spark - Won't start 19 May 2017 20:30 #762254
ozone wrote: ................. the coil wires have the original 1-2-3-4 stickers on them. They go left to right 1-2-3-4.
Correct?
Thanks.
Yes. When you are sitting on the bike facing forward the cylinder on your far left is #1. Ed
Plugs Spark - Won't start 02 Jun 2017 04:28 #763296
  • jdvorchak
  • jdvorchak's Avatar
  • Thank you received: 50
To verify if you have the coils wired incorrectly just temporarily swap 1&2 and 3&4 plug wires. If it starts you know you have the coils wired backwards.
Don't fix it until it's broken.
John
83 KZ550M1
83 KZ1100LTD
Also own:
2010 Harley Ultra Classic Limited, 2008 Harley low rider 71 CB350/sidecar
Plugs Spark - Won't start 02 Jun 2017 18:08 #763370
  • ozone
Figured it out. I took pictures of a bunch of stuff before I took it apart.
There are 3 wires coming out of the points. Black, green, and blue/red. These wires go up to the coils. When putting it together,
I naturally wire the same color to color. My brother looked at the picture I took prior to disassembly. He said, " oh look at that
they have green to black and black to green!!!!! WHAT!!!!
I switched wires and it fired right up. Has anyone seen this? Is this the correct wiring? According the to wiring diagram
it should be green to green and black to black.
Plugs Spark - Won't start 02 Jun 2017 20:27 #763379
  • jdvorchak
that tells me you have the coils wired backwards from stock. And that also means the spark plug wires are crossed. If it runs leave it alone. But if you swap the coil wires to black to black and green to green you will also have to swap the spark plug wires 1&2 and 3&4.
Wired correctly the left coil fires 1 and 4 and the right side coil fires 2 and 3.
John
83 KZ550M1
83 KZ1100LTD
Also own:
The following user(s) said Thank You: ozone
Plugs Spark - Won't start 02 Jun 2017 20:42 #763381
  • Thank you received: 2098
KZ650
The large fours, Z1, KZ900 and KZ1000, are wired the same, but with the coils being mounted in the reverse positions
(i.e., green-wired coil is mounted on the right, firing the two middle plugs which are #2 and #3).
The KZ650 wiring diagram is confusing because the plugs as pictured aren't in 1-2-3-4 order and aren't numbered.
Below, I have added the plug numbers in red print.
Good Fortune! :)
Last edit: by Patton.
Plugs Spark - Won't start 03 Jun 2017 05:51 #763393
Good Fortune! :)
  • Page:
  • 1
  • 2
