Bad Ignition Coil vs Bad Spark Plugs
- JWKZ750
28 Apr 2017 20:20
Hello Bike Gurus:
So, stalling, backfiring and sputtering.
Would you chalk this up to Ignition coil or spark plugs, if we are ONLY talking about whether it could BE either Spark plugs or Ignition Coil?
Re: Bad Ignition Coil vs Bad Spark Plugs
28 Apr 2017 20:24
Valves, carbs, bad wires or cap, etc.
- JWKZ750
28 Apr 2017 20:32 - 28 Apr 2017 20:37SWest wrote: Valves, carbs, bad wires or cap, etc.
Only happens when the bike gets warm and some say thats a dead giveaway its most likely the coil. This post isnt about my Kawa. Its about my Yamaha XS650, and the problem happened today, ONLY when it gets warm. Its def not the valves carbs or wire. ALL of those things were redone. New wiring harness, valves adjusted etc. Only the coil and plugs werent changed. The bike isnt getting spark = most likely coil. This photo was taken today. It was 83 degrees in NYC:
Last edit: 28 Apr 2017 20:37 by JWKZ750.
- Tyrell Corp
28 Apr 2017 20:45
Coil sounds suspect, put the multimeter away this is likely an insulation resistance issue. But after plugs, caps, leads and LT terminals clean up / recrimp issues are eliminated .
My 750 had a (one) new coil on it when bought it, 4000 miles later and the other side went awol.
- JWKZ750
28 Apr 2017 20:51Tyrell Corp wrote: Coil sounds suspect, put the multimeter away this is likely an insulation resistance issue. But after plugs, caps, leads and LT terminals clean up / recrimp issues are eliminated .
Yeah Im 9000% sure its the coil mostly because, as soon as I let the bike sit for a bit, it starts right up. The faulty coil does not like warm temps
- Tyrell Corp
28 Apr 2017 21:07
Precisely. Put the meter away...only after other more usual issues eliminated
"Eliminate all other factors, and the one which remains must be the truth."
Arthur Conan Doyle
Arthur Conan Doyle
- bountyhunter
29 Apr 2017 00:47TRUEJWKZ750 wrote:SWest wrote: Valves, carbs, bad wires or cap, etc.
The following user(s) said Thank You: JWKZ750
29 Apr 2017 04:33JWKZ750 wrote:Tyrell Corp wrote: Coil sounds suspect, put the multimeter away this is likely an insulation resistance issue. But after plugs, caps, leads and LT terminals clean up / recrimp issues are eliminated .
One way to test it is to use a hairdryer to warm up the coil when the bike is cold and see if the problem happens. Ed
- JWKZ750
29 Apr 2017 04:46 - 29 Apr 2017 04:46
In re the hairdryer trick, there are a TON of other symptoms that point to it being the coil, like the backfiring even though the carbs, jetting etc have all been checked. After posting this topic I did a LOT of research and im changing the coil. I bought one a month ago when the problems were so serious, but didnt put it in as it was still Winter, and I wasnt riding the bike (i was riding my other ones). So I will put the coil in and Im sure that will take care of it. I will keep you posted.
Last edit: 29 Apr 2017 04:46 by JWKZ750.
- JWKZ750
29 Apr 2017 04:55Tyrell Corp wrote: Precisely. Put the meter away...only after other more usual issues eliminated
Arthur Conan Doyle
His statement, and yours a bit, kinda confused me. I took it to mean hes saying its DEFINITELY the coil so dont bother checking it. Im I reading that right? Sometimes texting and internet messages can be read a number of ways.
- VTEC
29 Apr 2017 16:17 - 29 Apr 2017 16:19
Not familiar with the bike, but If it's got points check the gap and/or dwell before changing any parts. A bad capacitor may cause similar symptoms also.
KZ1000-K2
ZRX1100
XR400R
ZRX1100
XR400R
Last edit: 29 Apr 2017 16:19 by VTEC.
- JWKZ750
29 Apr 2017 18:34VTEC wrote: Not familiar with the bike, but If it's got points check the gap and/or dwell before changing any parts. A bad capacitor may cause similar symptoms also.
At this point im pretty sure its the coil.
