1980 KZ750 LTD H1 - front signal light problem
- braddlesnake
09 Dec 2016 18:41
I've got a funny problem with my front signal lights, they come on fine but they don't flash. I changed both flashers out but I still have the same problem.
Any ideas?
thanks for your time.
Brad
Any ideas?
Brad
- dvnsta
Re: 1980 KZ750 LTD H1 - front signal light problem
09 Dec 2016 19:12 - 09 Dec 2016 20:40
Would check your flasher relay there should be two of them. One is for hazard lights and the other handles the turn signal blinking. If not the flasher relay would clean all terminals and clean up the ground wires on each of the rear turn signal lights they can cause that as well.
1982 KZ 750 LTD H3 stock except with custom seat skin and kawasaki period backrest.
Kawasaki 1989 eliminator 250 b3
Last edit: 09 Dec 2016 20:40 by dvnsta. Reason: Miss spelling
The following user(s) said Thank You: braddlesnake
09 Dec 2016 20:05
If the battery charge is low they will do that.
- rrsmsw9999
09 Dec 2016 22:50
Also some years have 3 wires - dedicated ground, others 2 wires - the light must be rubber insulated the appropriate grommets. When I did not use the grommet with a two wire light the flash would not operate, but the light would. My 0.02$ R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
- Tyrell Corp
11 Dec 2016 16:53
Digital flasher units tolerate low voltage better. But this ain't your problem.
I would firstly check your black/yellow ground earths on all of them, it is common fault. Get a jumper wire and go black/yellow to a good ground on the frame or engine.
If in doubt add an extra ground back and front. i do on all my bikes. The black/yellow ground is all conected in the wiring loom with crimps below the wrapping, to one central ground - the battery -ve.
Over the years these can deteriorate and unless you hack the main loom apart it is difficult to rectify, so I just add a couple of extras.
This exact problem mainfests itself in two wire winkers as in one staying on all the time. You see it on rusty old vans all the time -the rear loom ground is defective so the back lights 'ground' through the indicators and vice versa. Crazy and seemingly illogical things happen when electrons can't find their way home.
