Number 2 cylinder not firing
  • JoHNY
  • JoHNY's Avatar Topic Author
08 Sep 2016 10:11 - 08 Sep 2016 10:15
#741545
Compression tested, checked valve clearances, cleaned carbs countless times, new coils, leads and plugs. Fires on number 2 intermittently but when it gets hot on a run, all 4 fire . It's like if I thrash it all 4 will fire. Number 2 seems hesitant then kicks in. Any suggestion guys?
Kawasaki Z750P7 Spectre, Triumph Daytona 955i, Honda CBR1000FN
Last edit: 08 Sep 2016 10:15 by JoHNY.
  • westmiltonfab
  • westmiltonfab's Avatar
Re: Number 2 cylinder not firing
08 Sep 2016 13:02 - 08 Sep 2016 13:04
#741565
I do not consider myself an expert by any means, But if it has fuel, compression and spark it is going to fire. I would guess ignition. Unless the bike is fuel injected.. Then I would suspect that.
Im curious to hear what everyone else thinks
1980 Kz1000 A4 21000 miles
2005 Road King 150,000 miles
1968 CL125 Honda 11,000 Miles
Last edit: 08 Sep 2016 13:04 by westmiltonfab.
  • missionkz
  • missionkz's Avatar
08 Sep 2016 13:18 - 08 Sep 2016 13:21
#741571
If everything you say is true, the carbs are clean and flowing properly, coils are new spark plugs are new, new plug wires .... etc. etc. my first guess would be that you have a short somewhere in the primary side of the ignition coil or the secondary side if a four cylinder and sometimes those shorts are right where the coils mounted to the frame..
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Last edit: 08 Sep 2016 13:21 by missionkz.
  • SWest
  • SWest's Avatar
  • 10 22 2014
08 Sep 2016 16:58
#741599
Pilot jet clogged. Use a guitar string or wire brush strand to make sure it's clear.
08 Sep 2016 18:24
#741624
Assuming the carbs are clean I'm guessing you have a problem with your petcock. The vacuum operated petcock has a vacuum line that runs from the petcock to the #2 carb. When the diaphragm inside the petcock gets wonky (and eventually they all do) it permits fuel to be sucked down through that vacuum line into the #2 carb throat and into cylinder #2. Then the #2 cylinder runs like crap. No fuel should ever be drawn through that vacuum line.
To test - You can remove the petcock vacuum line from the #2 carb and cap off the carb's vacuum nipple and the petcock vacuum line; this removes the vacuum line from the equation. Then install a new spark plug in #2 cylinder, turn the petcock to PRIME, and take a ride. If the problem goes away the petcock needs to be rebuilt or replaced. Ed
  • JoHNY
09 Sep 2016 02:42 - 09 Sep 2016 02:44
#741659
So confusing. I'm thinking it might be number 2 carb as there is a good spark to number 2. If I pull the plug from number 2 after it's been idling it looks wet and yet it doesn't seem to be firing. Number 2 exhaust is cold compared to the others. As I said once it gets hot number 2 hunts and wants to kick in. On a run if I crack the throttle number 2 works fine but if I open it gradually 2 wont fire. I've removed the vacuum tube, covered the carb hole and run the petcock on prime, no improvement.
Had the pilot screw out fired cleaner and compressed air through the whole carb
Last edit: 09 Sep 2016 02:44 by JoHNY.
  • 650mod
  • 650mod's Avatar
09 Sep 2016 08:54
#741689
+1 with what Ed said- I had that same issue last year. I tried a petcock rebuild kit, but that didn't last long until it went. This year, I tossed a replacement Suzuki petcock in from Z1 Enterprises, and I don't have the wet fouling issue anymore. Plus the whole petcock is the same price as the rebuild kit... Swaps right into place. You have to re-run the fuel line around the frame between the gas tank and seat due to the angle of the outlet nipple and spin the vacuum line 90 degrees, but other than that, it's more than worth the $40 to do. It's a way smaller petcock too which is nice.
One other issue that comes to mind is your float levels. Not sure if you've checked float levels, but this could be it too. I have this issue (lightly) on one cylinder at the moment that I need to fix.
www.z1enterprises.com/product/KL18-4359
Attachment petcock.jpg not found
Attachment line1.jpg not found
Attachment line2.jpg not found
78 kz 650 custom
Wiseco 720cc big bore
Dynajet stage 3 carb kit with pods
2002 Kawasaki Z750 exhaust
2001 Buell lightning front end
1999 Ninja 600 swingarm with 1999 Ninja 900 rear rim
converted to monoshock rear
Too many goodies to list fully
The following user(s) said Thank You: JoHNY
  • JoHNY
10 Sep 2016 09:36 - 10 Sep 2016 09:37
#741779
Tested it again last night and all 4 are 125PSI cold, good spark and no breaks in the wires. It must be number 2 carb, but I've cleaned the fucking thing countless times. Gas seems to get to the bowl but not much is getting into the chamber I'm assuming. As I said before once it gets hot it goes fine, totally stumped
Last edit: 10 Sep 2016 09:37 by JoHNY.
  • Julian_Boolean
  • Julian_Boolean's Avatar
Re: Re:Number 2 cylinder not firing
10 Sep 2016 10:43
#741784
Have you checked the carb rubbers?
  • JoHNY
10 Sep 2016 14:29
#741792
Yes buddy, think I've been through everything.
  • missionkz
10 Sep 2016 16:10 - 10 Sep 2016 16:11
#741795
With fresh dry spark plugs, have you tried filling all the bowls, pinch off the fuel lines, to be sure the #2 is not sucking raw gas through it's vacuum port? That would be the engine running on stored fuel in the bowls.
Bruce
1977 KZ1000A1
Last edit: 10 Sep 2016 16:11 by missionkz.
