- Thank you received: 16
My Starter Is Wheezing - Maybe It Has Asthma
- WABBMW
- Let The Good Times Roll !
22 Jul 2016 14:13 #735879
by WABBMW
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
My Starter Is Wheezing - Maybe It Has Asthma was created by WABBMW
On my 1982 KZ650, I replaced the 652 cc cylinders and pistons with 738 cc from another engine. The bike has so much more power and compression. After 37,000 miles I had to replace the brushes in my starter. They were worn completely away.
Now the bike cranks over well and fires up immediately. The odd thing is that sometimes the starter makes this "wheezing" sound as it winds down. Everything functions very well, but I wonder if there might be other repairs on the horizon due to this sound. Anybody experience this? Thanks.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
- Thank you received: 2749
22 Jul 2016 16:06 #735894
by SWest
Replied by SWest on topic My Starter Is Wheezing - Maybe It Has Asthma
Did you grease the bushings? Also the starter clutch could be going out.
- WABBMW
26 Jul 2016 14:09 #736307
by WABBMW
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
Replied by WABBMW on topic My Starter Is Wheezing - Maybe It Has Asthma
Yes, I did grease the bushings quite well. You are probably correct about the starter clutch. If I understand how it works, the engine spins the clutch upon starting, and this disengages it from the flywheel, but would also explain the "wheezing" sound. I will live with it for a while, and post up when I discover what it is. Just hate to tear into something that is working so well.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
26 Jul 2016 21:00 #736348
by SWest
The starters the are chain drive have a habit of making that noise before they fail.
- bountyhunter
- Thank you received: 337
27 Jul 2016 00:28 #736353
by bountyhunter
Replied by bountyhunter on topic My Starter Is Wheezing - Maybe It Has Asthma
Sounds like the added load from high comp is causing the starter to draw a lot more current than it's designed for. Probably hard on batteries and starters.WABBMW wrote: On my 1982 KZ650, I replaced the 652 cc cylinders and pistons with 738 cc from another engine. The bike has so much more power and compression. After 37,000 miles I had to replace the brushes in my starter. They were worn completely away.
- Tyrell Corp
- Thank you received: 261
27 Jul 2016 05:13 #736357
by Tyrell Corp
Replied by Tyrell Corp on topic My Starter Is Wheezing - Maybe It Has Asthma
Slipping starter clutch makes an awful screeching noise, starts occasionally on the compression 'bump' but then gets worse.
The sound is quite unmistakeable, not really wheezing more screaming.
(On the 400-750cc air cooled fours the starter turns the primary shaft to crank via the primary chain. 900-1100 series the starter clutch is direct on the crank )
27 Jul 2016 07:10 #736372
by SWest
The chain slack whipping contributes to the starter clutch making noise.
