Plug wires and spark plug dilemma (750 4cly)
- jcurriert
27 Jun 2016 14:07
So bike wont run it would run before.....
i think i got 1 bad spark plug.... i narrowed it down by switching it around and touching the plug on the case and turning it over.
went to town bought the stock BR8ES like it calls for......
well got home and the plugs that are in it got BR9ES threaded end type plug.
Looks like all the boots call for a threaded end
The BR8ES i got were a solid post.
What do i do??? do i continue running a threaded post br9es? or switch to a threaded post br8es if there is such a thing?
-Black 1981 KZ750 LTD (Sold)
-Met. Blue 1982 KZ750 LTD(currently fixing)
-Blue 1982 KZ750 LTD parts bike (parting out)
Re: Plug wires and spark plug dilemma (750 4cly)
27 Jun 2016 14:10
I've never seen plugs that didn't have a screw-on post. Are you sure you can't unscrew the post to reveal the threads? Ed
27 Jun 2016 14:52
I bought four B8Es plugs last year. One had a solid post. I returned it and got a new one. You might have bad plug caps. The dealers or dirt bike shops should have them. Pics of old plugs?
27 Jun 2016 15:15
The proper plugs are B8ES, not BR8ES (the R = resistor, which you don't want).
B9's are colder, which you don't want either.
Get some proper plugs.
- jcurriert
28 Jun 2016 03:32Nessism wrote: The proper plugs are B8ES, not BR8ES (the R = resistor, which you don't want).
Only reason i say R is NGK site calls for the resistor plug in my bike?
1982 Kz750 H
- jcurriert
28 Jun 2016 03:34im guessing my caps are fine sence swapping the plugs around showed that it was the plugs acting up. not the boots or coils.swest wrote: I bought four B8Es plugs last year. One had a solid post. I returned it and got a new one. You might have bad plug caps. The dealers or dirt bike shops should have them. Pics of old plugs?
28 Jun 2016 03:54jcurriert wrote:Nessism wrote: The proper plugs are B8ES, not BR8ES (the R = resistor, which you don't want).
1982 Kz750 H
That's because you're in Canada (see images below). Personally, I wouldn't use resistor plugs, but it's up to you. Ed
Attachment 00003a-2-3-4-5-6-7-8-9-10-11-12-13-14-15-16-17-18-19-20-21-22-23-24-25-26-27-28-29-30-31-32-33-34-35-36-37-38-39-40-41.jpg not found
Attachment 00003c-2-3-4-5-6-7-8-9-10-11-12-13-14-15-16.jpg not found
28 Jun 2016 05:05
Humm, guess I stand corrected. I would still run the regular non R plugs, in 8 heat range, not 9.
- JR
28 Jun 2016 05:25Nessism wrote: ...........I would still run the regular non R plugs, in 8 heat range, not 9.
I agree.... and i live in Canada. B8ES. Much better. Most plug caps have enough of a resistor in them without adding more in the plug.
- jcurriert
28 Jun 2016 14:11JR wrote:Nessism wrote: ...........I would still run the regular non R plugs, in 8 heat range, not 9.
but im not useing stock plug caps theyve been changed 2 are ngk and 2 are some other brand,,, would those have a resistor in them? Alot of ppl up here in Canada use snowmobile caps and plugs as they are easier to find and way cheaper... im kinda thinking thats what someone has done as every plug is a threaded tip not solid. I had to buy plugs that the tip threads off and chuck em.
anyhow no one stocks a br8es with threaded ends
so just for emergency use i threw a set of br9es threaded ends in to see how it ran. Well looks like the left pipe has alot of smoke so im going to have to look at the top of the engine for sure.... its probably coming out. I got another full top end i can swap over if i need. thx guys for your help.
Once the top end is finished up I might put a set of br8es or b8es depending on what i find out about these aftermarket caps and if they have a good resistor. thanks again
28 Jun 2016 14:50
Valve guide seals.
- jcurriert
28 Jun 2016 16:56my first guess was to do a compression test and see if its serious. If it has good compression all around... I would assume seals like you say. But if its lower compression in those 2 cly would it be hopefully just valve adjusment? It doesnt run as smooth as my 81 so im thinking somethings off somewere. It does seem to have the hard to idle bug... unless its just too much oil for proper combustion.swest wrote: Valve guide seals.
