1982 KZ1100 shaft headlight not working
  • psycobilly
  • psycobilly's Avatar Topic Author
20 Jun 2016 19:06
#732176
I'm sorry if this subject has been covered before, but I've been searching all over the web for 2 days with no results...
I just got an extremely clean original KZ1100 shaft for a steal. The guy couldn't get it to crank and I found that the ignition cylinder was jammed in the fork lock position. It would turn enough to light the gauges, but not all the way to "run". I fixed that by cutting off the fork lock tab on the frame neck and dismantling the ignition down to the base. Now it fires up and runs perfect :) .
The problem I have is everything works (turn signals, brake lights, gauge lights and horn), but the headlight doesn't in either position. There is no power at the plug, I tried bypassing the RLU (I think I did it right. Blue to blue/yellow wires in the 6 pin plug) and nothing. There is one burnt fuse space in the block (2nd from the right). Could this be the headlight circuit? If so, which wires go to that specific slot so I can cut and splice in an inline blade type fuse holder?
1982 KZ1100A2 57k miles, vetter fairing
  • psycobilly
Re: 1982 KZ1100 shaft headlight not working
20 Jun 2016 19:31
#732181
This is the fuse block. The melted tab is on the brake side of the bike.
  • SWest
  • SWest's Avatar
  • 10 22 2014
20 Jun 2016 20:11
#732185
Looks like you need to replace the whole thing.
  • SWest
  • SWest's Avatar
  • 10 22 2014
20 Jun 2016 20:16
#732186
No eBay APP ID and/or Cert ID defined in Kunena configurationHere's one with a pic of the wiring in back.
The following user(s) said Thank You: psycobilly
  • psycobilly
20 Jun 2016 20:23
#732187
That was my thought also. I was considering just ditching the box entirely and using the inline blade fuse holders as an upgrade.
  • SWest
  • SWest's Avatar
  • 10 22 2014
20 Jun 2016 20:28
#732188
No eBay APP ID and/or Cert ID defined in Kunena configurationOn the page there is a fusible link block too. You might have more than one problem.
  • psycobilly
20 Jun 2016 20:54
#732191
swest wrote: On the page there is a fusible link block too. You might have more than one problem.
Ya, that looks like what is mounted next to the fuse block. From all appearances, it looks good (at least from my automotive mechanic standpoint). Nothing looks burnt through like I would assume a fuseable link to do...
  • martin_csr
  • martin_csr's Avatar
21 Jun 2016 05:12 - 21 Jun 2016 05:14
#732212
KZ1100 fuse boxes w info embossed into the covers. the 1000-P police bikes have the same fuse box (82-2005).
nos 26004-1011
used --- see 4th pic
Last edit: 21 Jun 2016 05:14 by martin_csr.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
21 Jun 2016 19:12
#732326
Found my 1100A sixteen years ago and stripped the Vetter package off within a month. Thus began my short-term transformation which I thought finished several years ago...and each year since. :blink:
Its an addiction, u know. With ebay there is no end to the fix. Feed it! :woohoo:
1982 KZ1100-A2
  • SWest
  • SWest's Avatar
  • 10 22 2014
21 Jun 2016 19:16
#732328
:lol: :lol: :lol: The more I give, the more I get out of her. You should see my watch list. :woohoo:
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
21 Jun 2016 19:33
#732335
swest wrote: :lol: :lol: :lol: The more I give, the more I get out of her. You should see my watch list. :woohoo:
:lol: :lol: :lol: :silly:
Found it!:
1982 KZ1100-A2
  • SWest
  • SWest's Avatar
  • 10 22 2014
21 Jun 2016 19:48
#732338
You must be jarshing me. :lol: :lol:
