1982 kz750 lights work but won't turn over
  • Sheiswe
  • Sheiswe's Avatar Topic Author
09 May 2016 18:04
#725432
So I just replaced the battery on this bike. And now instead of the turn signals blinking now one lights up and I go to turn to start it and nothing. No click no attempt and its readying that my battery is weak and that there is no gas when there is. I'm trying to learn more about bikes so this is a personal project. Will not having the sensor that reads the battery acid level affect it from not starting?. Need help
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: 1982 kz750 lights work but won't turn over
09 May 2016 20:44
#725453
Do you have a manual?
  • TexasKZ
  • TexasKZ's Avatar
09 May 2016 20:54
#725454
Could be something as simple as a loose ground cable, or a corroded connection. Check both ends of both cables for clean, tight connections. A genuine factory service manual will be a big help. In the mean time, see if you can find some old posts on this forum by member MFolks. He has posted some pretty good general tutorials for checking electrical systems.
  • riturbo
  • riturbo's Avatar
10 May 2016 16:52
#725599
I can tell its a gpz but make and model would make it easier to help . If we knew what bike you had we might know where you can download a manual . Has it ever run or is this a new problem ? Check all the connections first . Then go to the clutch and kickstand switches .
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
  • riturbo
  • riturbo's Avatar
10 May 2016 16:52 - 11 May 2016 04:47
#725601
I can tell its a gpz but make and model would make it easier to help . If we knew what bike you had we might know where you can download a manual . Has it ever run or is this a new problem ? Check all the connections first . Then go to the clutch and kickstand switches . Have you checked the fuses ?
Some info here www.750turbo.com/manuals/Base%20Manual%2...20-%20Electrical.pdf
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
Last edit: 11 May 2016 04:47 by riturbo.
