Need new ignition coil for 1984 KZ440 D6
  • BornAgainBiker
  • BornAgainBiker's Avatar Topic Author
13 Apr 2016 14:29
#720770
It looks like its time to replace the coil on my KZ440 (I'm pretty sure that the one on it is the original).
The bike is showing all the signs of weak spark: the spark looks red instead of light blue, the plugs run a bit on the sooty side, the engine has a slight miss especially at higher rpms or under load, plus power and fuel mileage are sub-par.
So, I was wondering if anyone could recommend a good replacement coil for my ride?
All the best, Jeff
1984 KZ440 D6
  • bountyhunter
  • bountyhunter's Avatar
Re: Need new ignition coil for 1984 KZ440 D6
13 Apr 2016 16:34 - 13 Apr 2016 16:39
#720798
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationIf it has points, you can use any four Ohm coil. If it's electronic ignition, they usually use a lower Ohm coil but a four Ohm can be used with no problems.
Last edit: 13 Apr 2016 16:39 by bountyhunter.
The following user(s) said Thank You: BornAgainBiker
  • SWest
  • SWest's Avatar
  • 10 22 2014
13 Apr 2016 21:13
#720849
Are the points clean or new? Is there sparking at the points?
  • BornAgainBiker
14 Apr 2016 03:57 - 14 Apr 2016 04:17
#720861
It's electronic ignition. The wires, spark plugs and plug caps are new. Also the timing advance unit has been cleaned and lubed. :)
All the best, Jeff
1984 KZ440 D6
Last edit: 14 Apr 2016 04:17 by BornAgainBiker.
  • BornAgainBiker
14 Apr 2016 04:03
#720862
I see that there is a coil on ebay made by Caltric that fits my bike, but any reviews that I could find of their products were negative. Has anyone here had any experience with Caltric parts? :unsure:
All the best, Jeff
1984 KZ440 D6
14 Apr 2016 04:36 - 14 Apr 2016 09:31
#720866
Perhaps the weak plug spark is resulting from loss of voltage between the battery and the coil.
Question -- With the ignition switched ON and the engine NOT running, what is the measured voltage being received at the coil primary terminal as compared with the measured voltage between the battery posts?
The following illustration is an example of the several connections where voltage might be lost. (Just ignore the second coil in a dual coil system).
Good Fortune! :)
Last edit: 14 Apr 2016 09:31 by Patton.
  • martin_csr
  • martin_csr's Avatar
14 Apr 2016 05:09 - 14 Apr 2016 05:10
#720871
Could he use a Dyna ignition coil? either 2.2 ohm or 3.0 ohm? or are they not available individually?
Last edit: 14 Apr 2016 05:10 by martin_csr.
  • BornAgainBiker
14 Apr 2016 06:59
#720884
martin_csr wrote: Could he use a Dyna ignition coil? either 2.2 ohm or 3.0 ohm? or are they not available individually?
Thanks Martin, I was considering A Dyna coil as a possibility. :)
All the best, Jeff
1984 KZ440 D6
  • loudhvx
  • loudhvx's Avatar
14 Apr 2016 07:21
#720891
On ebay there are cheap replicas of the factory coils, sold individually. They are usually listed under Kz550 or other inline-four Kz's. My buddy bought two and they've worked great so far (about 10 months). You have to put new wires on them. They were like $40 each. Make sure to ask for bolt spacing and ohms if it's not listed. You want 2.2 to 2.6 ohms.
  • BornAgainBiker
14 Apr 2016 07:26 - 14 Apr 2016 07:27
#720894
Patton wrote: Perhaps the weak plug spark is resulting from loss of voltage between the battery and the coil.
Good Fortune! :)
Thanks for the great info Patton--I really appreciate it--what is acceptable voltage loss in the ignition system?
All the best, Jeff
1984 KZ440 D6
Last edit: 14 Apr 2016 07:27 by BornAgainBiker.
  • SWest
  • SWest's Avatar
  • 10 22 2014
14 Apr 2016 08:29
#720904
BornAgainBiker wrote: I see that there is a coil on ebay made by Caltric that fits my bike, but any reviews that I could find of their products were negative. Has anyone here had any experience with Caltric parts? :unsure:
I bought a Caltric R/R. It failed in a week and almost ruined my alternator. Cheap CHINESE JUNK. :lol: That's a boat. :lol: :lol: :lol:
14 Apr 2016 09:29
#720914
BornAgainBiker wrote: . . . what is acceptable voltage loss in the ignition system?
Would aim for no voltage loss or at least a very minimal voltage loss, because any loss is likely due to corrosion in the connections and/or switches between the battery and coil.
Could be helpful to verify the quality of spark produced when the existing coil is known to be receiving full voltage from a good fully charged battery.
Perhaps the existing coil is capable of producing fat blue plug sparks while the engine is being spun over via the electric starter (or kick starter if so equipped).
Good Fortune! :)
