Lost my highbeam at the shop
- wrenchmonkey
Re: Lost my highbeam at the shop
27 Apr 2016 00:09
Um...
Be Very Careful!
LED, when wired backwards become DED !
Nobody likes a Dark Emitting Diode!
Be Very Careful!
- kaw-a-holic
27 Apr 2016 04:50
Should be plug and play. It has the same H4 configuration so all he has to do is plug it in. Seems toe there is something else going on. Have you used a multimeter to verify correct voltage at the H4 connector?
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
- Rave71
27 Apr 2016 05:38
I have not, I have just been using the stock unit functioning as my "everything works" check. What should my voltage reading be at the plug?
1981 Kz750 ltd
Hudson Valley NY
USMC/OIF Vet
Hudson Valley NY
USMC/OIF Vet
- Rave71
27 Apr 2016 06:43Rave71 wrote: I have not, I have just been using the stock unit functioning as my "everything works" check. What should my voltage reading be at the plug?
Reply to myself... At the connector I am getting 12v constant and switched im getting 8v low beam and 12v high beam.
1981 Kz750 ltd
Hudson Valley NY
USMC/OIF Vet
Hudson Valley NY
USMC/OIF Vet
- kaw-a-holic
27 Apr 2016 19:10Rave71 wrote:Rave71 wrote: I have not, I have just been using the stock unit functioning as my "everything works" check. What should my voltage reading be at the plug?
I think you have answered your own question. You could check with the bike running and see if it increases.
Jon
1977 KZ1000a1
Mesa, AZ
1977 KZ1000a1
Mesa, AZ
