1980 KZ1000E2
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: 1980 KZ1000E2
05 Apr 2016 19:43
#719457
That could be the pick up is in the wrong place.
Re: 1980 KZ1000E2
05 Apr 2016 21:55
#719471
loudhvx wrote: . . . A check with the diagram would confirm this as well. Does anyone have a 1980 Kz1000E (shaft) wireing diagram, or even a 1979 Kz1000E1 ? . . . .
www.kzrider.com/filebase/download/94-kz1...000e1-wiring-diagram
Good Fortune! :)
  • loudhvx
  • loudhvx's Avatar
Re: 1980 KZ1000E2
05 Apr 2016 22:08
#719472
Thanks Patton.
I recommend not doing the jumper test. Based on the spark test on the primary, it sounds to me like one of the coils has a connection to ground, that it should not have if the crank is not turning. This can result in a cooked coil.
I would do voltage tests described earlier.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: 1980 KZ1000E2
06 Apr 2016 05:33
#719501
I wasn't suggesting hooking it up just touching the connector briefly to see if a spark occurs.
  • rrsmsw9999
  • rrsmsw9999's Avatar Topic Author
Re: 1980 KZ1000E2
06 Apr 2016 06:03
#719508
Don't sweat it, I was ready to plug into a wall outlet anyway :)
R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: 1980 KZ1000E2
06 Apr 2016 06:12
#719513
You must be joking. :lol:
