KZ 650-B2 Ignition Coil repeated failures.
  • rsilva
  • rsilva's Avatar Topic Author
21 Mar 2016 16:52
#716618
I have recently burned through 3 ignition coils on the same side of the bike. it is equipped with a Dyma electronic ignition, and has correct wiring based on manufacturer instruction. The Coils are made by EMGO. I have tested the failed coils and have found them inoperative.
Battery voltage: 12.6,
voltage leading TO COILS: 10.4
#1/4 COIL WORKS, BUT #2/3 DIES.
I have checked the rest of the electrical system and have found that it is reading 12.6 volts, and no fuses are blowing.
Pleas if anyone could help I would greatly appreciate it :(
If you want photos, I can provide them, just let me know.
  • car5car
  • car5car's Avatar
  • Banned
  • Banned
Re: KZ 650-B2 Ignition Coil repeated failures.
21 Mar 2016 16:57
#716619
If spark plug wires are bad, spark can burn coil. Check resistance of wires with coil and separately.
96 Yamaha Royal Star
82 Yamaha Virago 920
The following user(s) said Thank You: rsilva
21 Mar 2016 17:04
#716622
You may want to (at least temporarily) go back to using points and see if you experience the same problem. My 1977 KZ650 stock coils have lasted 39 years with no problems; I use stock points. Ed
  • SWest
  • SWest's Avatar
  • 10 22 2014
21 Mar 2016 17:05
#716623
Are the coils made in CHINA?
  • car5car
  • car5car's Avatar
  • Banned
  • Banned
21 Mar 2016 17:14 - 21 Mar 2016 17:16
#716625
Did you forget to use RTV? :)
My coil works fine.
2/3 coils should always be covered by gray RTV.
Use copper RTV for 1/4 coil. :evil:
Attachment IMG_1159.JPG not found
Last edit: 21 Mar 2016 17:16 by car5car.
  • RonKZ650
  • RonKZ650's Avatar
21 Mar 2016 18:33
#716638
Yea, I'm betting on Chinese coils. My 78 KZ650 with 168,000 miles still has original Kawasaki coils even using a Dyna system. I don't think the coils are generally a fragile item. If they were, I'm sure I would have burned mine out by now.
  • SWest
  • SWest's Avatar
  • 10 22 2014
21 Mar 2016 18:38
#716640
I have two sets of original coils and one set of Honda coils. They still work and none of them have RTV smeared all over them. nor would they ever be. B)
  • rsilva
21 Mar 2016 19:36 - 21 Mar 2016 19:39
#716649
the wires are fused into the ignition coil. should I try new connectors, and grounding the coil?
Also the coils are made in Taiwan, and it voids the warranty if i put paste on the coil. The coils are not melting or getting hot, they just stop working :/
Last edit: 21 Mar 2016 19:39 by rsilva. Reason: misstype
21 Mar 2016 19:56 - 21 Mar 2016 20:00
#716653
rsilva wrote: the wires are fused into the ignition coil. should I try new connectors, and grounding the coil?
How were the failed coils tested?
Many stock coils have integrated plug wires permanently built into them as part of the coil assembly.
Coil mounting does not involve a ground. If suspended in mid-air, a serviceable coil will work just fine.
Assure good contact between each plug wire and its cap.
Could consider trimming ΒΌ" off each plug wire to achieve better connections where the wire attaches to its cap.
Battery may be weak and still measure 12 volts.
Would have the battery load-tested after an overnight charge.
Load testing is usually a free service anywhere that sells batteries.
For testing purposes, it's okay to use jumper cables from an automobile battery so long as the automobile's engine isn't running.
Good Fortune! :)
Last edit: 21 Mar 2016 20:00 by Patton.
  • car5car
  • car5car's Avatar
  • Banned
  • Banned
22 Mar 2016 07:07 - 22 Mar 2016 07:34
#716713
rsilva wrote: it voids the warranty if i put paste on the coil. :/
it was a joke.
RTV is used to prevent cracks growing on old coils.
There is a resistor in diagram, is it installed?
Last edit: 22 Mar 2016 07:34 by car5car.
  • KZB2 650
  • KZB2 650's Avatar
22 Mar 2016 07:32 - 22 Mar 2016 07:32
#716721
10.4 volts leading to the coil sounds too low doesn't it guys?? Mine is 12.17 and 12.19 the last time I checked and my first Dyna coils lasted over 20 years before I decided to replace em.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 22 Mar 2016 07:32 by KZB2 650.
  • SWest
  • SWest's Avatar
  • 10 22 2014
22 Mar 2016 07:55 - 23 Mar 2016 06:13
#716730
Yes, bad connections or fried wires.
Last edit: 23 Mar 2016 06:13 by SWest.
