Bike horn vs. car horn?
  • car5car
  • car5car's Avatar Topic Author
  • Banned
  • Banned
04 Mar 2016 09:09 - 04 Mar 2016 09:10
#713784
Do bike horns have twice less power? If this is so, I need to install car horn.
Maybe mine is half dead.
96 Yamaha Royal Star
82 Yamaha Virago 920
Last edit: 04 Mar 2016 09:10 by car5car.
Re: Bike horn vs. car horn?
04 Mar 2016 09:22 - 04 Mar 2016 09:45
#713787
Would check out aftermarket motorcycle horns such as those offered by Fiamm, etc., and the various subcategories of electronic and air-powered models. Just Google Fiamm horns.
I suspect at least some 12 volt automotive style horns may require using a relay instead of being directly connected to the bike's stock brown wire that attaches to the anemic stock horn. The relay would be to allow direct current from the battery positive terminal to the horn and preserving normal function of the horn button by re-routing the stock Brown horn wire from the horn to the relay.
Some motorcycle horns have a screw adjustment that can be used to achieve the horn's inherent maximum volume (which may still be considered as pretty lame :( ).
Good Fortune! :)
Last edit: 04 Mar 2016 09:45 by Patton.
04 Mar 2016 09:44 - 04 Mar 2016 09:45
#713788
Using a relay, I installed a FIAMM 72112 Freeway Blaster Horn (Low Tone - F) horn in addition to the stock horn. The result is a MUCH louder horn. I mounted it up in the frame just behind the steering neck - it's invisible. I got it from Amazon. Ed
www.amazon.com/FIAMM-72112-Freeway-Blast...n+%28Low+Tone+-+F%29
Last edit: 04 Mar 2016 09:45 by 650ed.
  • theApehouse
  • theApehouse's Avatar
04 Mar 2016 11:43 - 04 Mar 2016 11:43
#713803
Back in the day, an old friend of mine was the local VW guru (classics of course). He also had a love for BMW aircooled motorcycles. His favorite thing to do was mount an old 6 volt VW horn on his bike. Because when he ran 12 volts through it, WOW..
1987 KZ1000P, dynatek 2.2 coils
www.youtube.com/channel/UC3VtY1XWwKH3zK2trI2Hz1w
Last edit: 04 Mar 2016 11:43 by theApehouse. Reason: spelling
  • SWest
  • SWest's Avatar
  • 10 22 2014
04 Mar 2016 11:47
#713804
I have two horns. High and low with a relay. The ground button can't handle two. The ground wire goes to the horn, the button completes the ground. With the puny stock horn I didn't get as much attention. Now they think a car or truck is coming at them :evil:
  • car5car
  • Banned
  • Banned
04 Mar 2016 13:06
#713814
When I go to junk yard, I'll get two car horns and relay. $2.99. It is expensive, but safety is important! :)
There was some bike with 2 horns under headlight. It makes sense, they shouldn't be hidden.
acepickapart.com/pricing.html?a=h
04 Mar 2016 14:26
#713834
I like my horn being hidden - it's still as loud as a car horn. However, for those who don't mind a little bit of extra horn showing, may I offer the following setup which is a bit louder than mine. ;) Ed
  • SWest
  • SWest's Avatar
  • 10 22 2014
04 Mar 2016 14:36
#713837
I want one. :ohmy:
