LED Tail Light Swap
  • Rave71
  • Rave71's Avatar Topic Author
LED Tail Light Swap
05 Feb 2016 10:51
#709547
Hey Guys, working on a 1981 kz750 I picked up last spring... It has been a nickel and dime garage cafe racer project for me. Well I finally got a few days this winter to work on her and I chopped up the rear fender and put on a new combo tail/brake/turn signal LED setup. The problem I have come across in wiring them is the unit I purchased has 5 wires and the bike side has 7. I tested and labeled all the wires and actually have the unit functioning properly. The two extra wires on the bike side are black with a yellow (or perhaps white) stripe and from what I have read these are turn signal ground wires.
The frustrating part of all this is with those wires disconnected the brake warning light on the instrument cluster blinks rapidly indicating a malfunction with the rear lights. Just wondering if anyone has solved this issue already, is there somewhere I can run those wires to make the system function correctly? If not, is there a way to disable that flashing brake light indicator? I'd like to not pull out the bulb as it is also the oil warning light. Thanks in advance for your help.
JC
1981 Kz750 ltd
Hudson Valley NY
USMC/OIF Vet
  • Rave71
Re: LED Tail Light Swap
05 Feb 2016 12:55
#709579
Just to clarify what I am talking about:
Picture shows the five wires connected to the new unit as well as the two leads (which are spliced from one common wire) that have no connection point. And to correct my previous post, the gauge lamp is the brake/fuel indicator.. Not the oil lamp.
1981 Kz750 ltd
Hudson Valley NY
USMC/OIF Vet
  • SWest
  • SWest's Avatar
  • 10 22 2014
05 Feb 2016 14:20
#709613
The B/Y is the ground. Try using them instead of grounding to the frame.
  • Rave71
05 Feb 2016 15:41
#709621
So use that ground instead of the other black wire coming from the other part of the harness?
1981 Kz750 ltd
Hudson Valley NY
USMC/OIF Vet
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • redhawk4
  • redhawk4's Avatar
05 Feb 2016 16:11
#709624
If the light is flashing it's telling you the bulb is gone if I remember correctly, so because you have an LED set up which is very low wattage it thinks the bulb is blown, There's a unit that controls all that, you'd probably need to put a resistor in the circuit, in line with the stop lamp to fool it or remove the whole thing and wire it so it purely lights up in the instrument cluster when the brake light operates or just do away with the whole idea.
If you look up in line resistors for LED turn signals you will get an idea of what I'm talking about as they use them there to stop the signals flashing too fast due to the low resistance of the LED bulbs if they don't change the flasher unit to an LED one.
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
  • SWest
  • SWest's Avatar
  • 10 22 2014
05 Feb 2016 16:25
#709629
I switched to LED's. My turn signals wouldn't flash. I had to get a flasher for them. When I went to AZ and OR asking about one I got the Fish eye. They sell the LED's and the resisters. They pull about the same power as the bulbs and defeated the purpose of having LED's in the first place. My tail light is still a bulb. The warning light wouldn't work without it.
  • Rave71
05 Feb 2016 17:26 - 05 Feb 2016 17:33
#709639
I swapped out the turn signals last year with LED's and had to do the same thing, upgrade the flasher to get them to opperate correctly. I will look into a resistor and see if that does the trick. I would want to wire that into the brake circuit power wire correct?
Edit:
Or Swest were you saying that it won't work period without a standard bulb?
1981 Kz750 ltd
Hudson Valley NY
USMC/OIF Vet
Last edit: 05 Feb 2016 17:33 by Rave71.
  • SWest
  • SWest's Avatar
  • 10 22 2014
05 Feb 2016 17:28
#709641
Yes and use the ground wires both tail and signals.
  • Rave71
05 Feb 2016 17:34
#709644
Ok great, I'll give it a shot. Thank you for the help.
1981 Kz750 ltd
Hudson Valley NY
USMC/OIF Vet
  • redhawk4
  • redhawk4's Avatar
05 Feb 2016 17:44 - 05 Feb 2016 17:47
#709646
Rave71 wrote: Ok great, I'll give it a shot. Thank you for the help.
Just put the resistor in series with the live wire connection before the bulb, you could work out the size of resistor from the wattage of the bulb, but as those are the same wattage bulbs as turn signals then whatever they sell for those would be the correct number of ohms.
For turn signals definitely get an LED flasher unit, I got one for a Yamaha Cafe bike I had with LED signals from a local auto parts store it was for a GM car with LED signals, I think it was about $12 and worked fine. That way you get LED signals and the saving in power consumption which you will lose with a resistor as Swest points out.
1977 KZ650B1
1980 Suzuki SP400
Last edit: 05 Feb 2016 17:47 by redhawk4.
  • Rave71
10 Feb 2016 06:56
#710269
So I got my resistors in the mail and finally got back down in the garage to play around with them. First I tried wiring the resister in the brake light circuit but my indicator still was flashing. Next I tried it in the tail light circuit, same problem and finally I tried putting one in both circuits and the light was still flashing away. Everything functions properly I just know that the flashing light will drive me nuts if I button it all up and leave it as is. If anyone has an other ideas please let me know.
1981 Kz750 ltd
Hudson Valley NY
USMC/OIF Vet
