help with blinkers
- strum
help with blinkers
24 Jan 2016 04:47 - 24 Jan 2016 04:48
My left blinker has always been slower than my right . I didnt think much of it but i had took off my gauges to fix some bown bulbs and after putting them back in . I gave it all a test(headlight out) everything worked excpt the left blinker. so after messing with wires in the bucket looking for poor connections bad grounds ect .. i got it to blink(still slower than the right side) but when i plug in the head light it stops.
any thoughts? This is on my 1000 st and all test are with the bike not running (still dont have my fuel tank back from paint)
but the battery tests full charge..
Blairsville Ga.
1980 KZ1000 Shaft (sold and missed already)
2003 ZRX 1200R (sold)
2003 Concours ZG1000 (just purchased)
Last edit: 24 Jan 2016 04:48 by strum.
- redhawk4
Re: help with blinkers
24 Jan 2016 07:09
That sounds like a bad ground connection somewhere to me. Try connecting a wire directly to the _ve battery terminal and then touching it to the ground connection at the turn signal.
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
1977 KZ650B1
1980 Suzuki SP400
- strum
24 Jan 2016 09:32redhawk4 wrote: That sounds like a bad ground connection somewhere to me. Try connecting a wire directly to the _ve battery terminal and then touching it to the ground connection at the turn signal.
I found it ..you were mostly right ..i took all 4 blinkers apart and found the ones in the rear are in need of replacement..one of em had no gasket and was a corroded mess.. i cleaned em all up the best i could and used de-oxit on all the connections..I even went through all the connectors inside the headlight housing . everything is working great now ..very bright and blinking properly.
Its a temporary fix until i can replace those in the rear. but at least i made headway.
Blairsville Ga.
- strum
24 Jan 2016 12:40
I want to say that this forum really is a great help to me. I did a search and found a post about cleaning all the connectors on the whole bike.
II haven't gotten to em all yet but im knocking em down little at a time.
it makes a huge difference and as i go along i find little things here and there that need attention. Like for instance when i removed one of the rear turn signals i found a wire with damaged/worn insulation.. A little shrink tube and i was done.
Fix em now instead of on the side of the road.
Stan
Stan
Blairsville Ga.
24 Jan 2016 15:11
Good thinking.
- Kidkawie
- I bleed premix
25 Jan 2016 03:31strum wrote: I want to say that this forum really is a great help to me. I did a search and found a post about cleaning all the connectors on the whole bike.
Stan
Disconnect the battery and start working your way from the battery out cleaning all connections and applying dielectric grease when clean. shouldn't take long after removing the tank, side covers and headlight. You should also consider disassembling and cleaning the handlebar switches.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
