Possible Grounding Issue
- 1977-Z1-A1-LTD
27 Oct 2015 07:22
Hey all, I've been slowly sorting through the electrical on my 1977 KZ1000 (LTD). I went through the tedious process of trying to salvage the existing harness and correct multiple wiring nightmares, even found several wire nuts that were used by PO to make connections. Long story short, the wiring was too far gone so I opted for a new harness to basically start over. As I have been re-connecting all of the components using a decent color wiring diagram I found on-line (printed on 11x17 paper in color at work), I have been checking and double checking where things belong using a continuity meter. For two reasons (a) the original wiring was a mess and some of it replaced with different color wires and (b) don't trust that the new harness has the correct color combinations. In my checking I noticed that when the ignition is on the rear light gets power (red wire from ignition switch for running mode dual filament bulb). If I connect my meter to this red wire, I get continuity between this hot lead to the running tail light and ground (frame, battery, motor all give signals). I have not connected the battery at this point, so this is all based on checking for ground fault using a meter. Is this normal? If I take the bulb out, the continuity is lost... Any help would be appreciated, wiring is not my thing for sure.
1977 KZ1000 LTD
1990 FXR
1998 KTM 300 EXC
1974 CBR 350
1990 FXR
1998 KTM 300 EXC
1974 CBR 350
- Tyrell Corp
Re: Possible Grounding Issue
27 Oct 2015 07:37 - 27 Oct 2015 07:40
Yes, if you set it to ohms you will read the resistance of the bulb filament. Circuit is hot through the bulb to ground.
Removing the bulb and going hot to the bulb holder centre contact gives continuity, also continuity from the side of the bulbholder to ground.
If you had a fault like hot to ground without the bulb fitted then that would would pop the fuse.
The bulb's resistance acts to limit the current, a 'dead short' has minimal resistance hence high current flow hot to ground.
if you bridge the centre terminal and outside of the bulbholder with a screwdriver to simulate a wiring fault that would allow well over 10 amps current hot to ground hence the fuse would pop.
'Hot' = +
'Ground' = -
'Hot' = +
'Ground' = -
Last edit: 27 Oct 2015 07:40 by Tyrell Corp.
The following user(s) said Thank You: 1977-Z1-A1-LTD
- 1977-Z1-A1-LTD
27 Oct 2015 08:44
Many Thanks Tyrell Corp! This is a huge help and now I can move ahead.
1977 KZ1000 LTD
1990 FXR
1998 KTM 300 EXC
1974 CBR 350
1990 FXR
1998 KTM 300 EXC
1974 CBR 350
- MFolks
27 Oct 2015 11:22
Wire nuts(the type that resemble a cone, with a wire spiral inside, that electricians use), and the 3M "Splices" with the blade that pierces adjacent wire conductors), should never be used in a environment that has moisture, or gets wet, as corrosion and resistance will quickly form, having you wonder why your bike has dim lights, weak spark, and the horn barely functions.
- MFolks
27 Oct 2015 11:25
Cleaning Motorcycle Electrics I recommend doing this every two years if possible.
Get some of the De-Oxit electrical contact cleaner and figure on spending a good day going from the front of the bike to the back. It’s a plastic safe cleaner/preservative. www.deoxit.com is their website.
On the older Kawasaki's, a majority of electrical connectors are inside the headlight housing requiring removal of the headlight, then the fun begins.
Do one set of electrical connectors at a time to avoid mixing up what connects to where. Usually disconnecting, spraying with De-Oxit and reconnecting is about all you'll need.
However, when encountering the green crud of corrosion, a brass wire brush may be needed on the pins you can reach.
Some 400-600 grit wet and dry sandpaper strips rolled into a tube should reach the male and female pins in the more difficult to clean connectors.
Smoker’s pipe cleaners, cotton swabs and wooden toothpicks work as cleaning aids.
Really small electrical connectors may require the use of a welders tip cleaning tool assortment.
Most pins in the connectors are coated with a thin plating of tin, and others may be nothing more than copper or brass.
If moisture is added, the resulting corrosion lowers the voltage/current being carried causing dim lights, slow engine cranking, slow turn signal response and lower input voltage to the ignition coils resulting in weak spark.
The left and right handlebar switch pods will need attention too as they have circuit functions like turn, horn, run/stop, and start.
Usually a spritz or two with actuation of the switch is about all needed for these switches unless corrosion is detected and then careful disassembly is required.
The ignition switch may or may be not sealed to allow spraying the internal contacts. I urge caution if attempting to open this up as springs, and ball bearings may fly out never to be seen again!
If your bike has the older style glass tubed fuses, I suggest replacing them as vibration can cause internal failure. AGX is the type used, and most auto parts stores can get them for you.
Clean the fuse holder clips, looking for signs of overheating(discolored insulation, signs of melting).
I use metal polish on a cotton swab, followed by spraying another clean swab with the De-Oxit and then rubbing the inside of the fuse clip.
All battery cables must be clean and tight for maximum current transfer. Check the cables going from the Negative(-) battery terminal/post to the engine mounting bolt
Also the one going from the Positive(+) terminal to the starter solenoid and from there to the starter motor.
If any battery cable feels ”Crunchy” when flexed, replace it as possible corrosion is inside the insulation.
Each "Bullet Connector" will have to be sprayed to ensure good connectivity, especially the ones going to the energizing coil of the starter solenoid.
The alternator output “Bullet Connectors” are usually behind the engine sprocket cover and will need inspecting and cleaning too.
The turn signal light sockets will benefit from a spritz from the contact cleaner along with the tail light/brake light socket.
Some brake light switches can be sprayed on the actuating rod, with the spray running down inside to the electrical contacts, others may be sealed requiring replacement if the switch is intermittent in operation.
Some people put the Di-Electric Grease on cleaned terminations/connectors, I don’t, as I’ve read/heard it can cause problems when it gets hot, actually insulating the connections, so the choice is yours to use or not.
“I spent a weekend going through every electrical connection and switch on the bike with a little scotchbrite pad and DeOxit - what a difference! Everything was brighter, gauge backlights, indicator lights, turn signals, I was getting a nicer spark, it fired up quicker, etc. Well worth my time. WELL worth it! “
From a forum member at www.kzrider.com
Re: Cleaning the many and various Motorcycle electrics.
I used the De-oxit D-5 spray on all the electrical connections of my 78 Kz1000 that had sat for twenty years .
When I parked the bike in 92 I was starting to have troubles with some of the electrical system, but after pulling everything apart and giving it a spray , reconnecting the connectors and working them back and forth a few times, then gave them another shot of spray to wash them off before the final reconnection.
Everything still works perfectly and has for over 7000 miles this year.
I am extremely happy with the results , a lot of the connectors were green when I started and after the cleaning they looked new ( shiny gold )
I found the Deoxit D-series, D-5 spray in a 4 oz can at a big electronics store called Frys in Illinois, don't get the small cans at Radio Shack , they are different and meant for computer type stuff.
store.caig.com/s.nl/sc.2/category.188/.f
Recommendations:
Excellent contact cleaner from audio to ac power contacts
I've been an A/V Tech-Roadie for over 30 years and have used Deoxit since it was first introduced. I've cleaned /rejuvenated volume controls,switches and audio connections on everything from guitar amps to full blown recording consoles. It not only cleans mild to excessive corrosion but the lubricant keeps the part in good working order months afterwards. Much easier than replacing a hard to replace part. I also spray it on all the audio connectors periodically to insure good connectivity. Along with my A.C. power plugs and quad boxes that are used outside for live shows to prevent corrosion from the elements.
Good stuff. Obviously highly recommended.
Great Stuff
I used this stuff on my 35 year old Kenwood KA-7300 amp which had not been used in more than 10 years and it was fantastic. When I first tried to use the amp, all of the switches only worked sometimes and the static and intermittent sound was unbearable. I thought that my left channel was not working because it had such a low output compared to the right channel no matter where the balance was set. After cleaning all the input/ and output jacks and the switches along with vacuuming out the inside of the amp, the amp works great and sounds like it did back in the day! I was more than pleasantly surprised!!
I've used DeoxIT for years. My first use was on a BMW instrument cluster that an $800 "reno" hadn't fixed. I sprayed the several connectors and mates, dozens and dozens of connectors, let it sit overnight and reinstalled it in the car. That cured every problem. Years after manufacture one or more of those connections could get iffy, and they do. Since then I've fixed several instrument clusters, engine and transmission computer problems caused by the same thing, connections, and no telling how many other electrical connection problems in cars.
An Effective cleaner-rejuvinator!
I used this to clean the pots, switches, and faders on my old Allen & Heath SR416 mixer. Everything is working top-notch again and everything moves/slides with ease. DeoxIT is a great product and it always improves sound quality and equipment life. This is the only cleaner you need!
Trust MFolks , the guy's a true rocket scientist and really knows what he's talking about.
JD
Recommendations:
Great Stuff
JD
- Tyrell Corp
27 Oct 2015 14:52
+1
Sorting electrics is very satisfying, bright lights everywhere and on the button starting - you can see the difference in the brightness of the neutral light etc. Also usually a cheap fix if you know what you are doing. Most breakdowns are electrical.
