82 GPz750 battery warning light
- GPzMOD750
19 Oct 2015 04:04
My battery warning light was blinking most of the way to work. The volt meter reads 12-14v idle to speed with smooth running assy all revs. It seems like the light is blinking some sort of pattern then will stop. I don't have the manual with me and I no longer have a center stand so I can't check my battery water levels until I get it home and on a paddock stand. Is there anything else I should look for besides loose connections and shorts?
- scubaanders
Re: Re:82 GPz750 battery warning light
19 Oct 2015 05:25
The battery warning light tells you that the electrolyte level is low.
When replacing the battery it's common to put a fuse ans connect it to +
/A
/A
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
The following user(s) said Thank You: GPzMOD750
- GPzMOD750
19 Oct 2015 05:37 - 19 Oct 2015 07:11
Thanks, I was thinking that was the primary purpose of the light but since I don't have my FSM I wanted to double check. I'm also going to trace my wires to see if there is anything that might be getting wet. I went on a short ride yesterday evening and got sprinkled on. Also got a little wet this morning. Since it doesn't have the fairing and a smaller headlight bucket I might be getting a little moisture on some wires.
Last edit: 19 Oct 2015 07:11 by GPzMOD750.
- scubaanders
19 Oct 2015 05:42
If it's a cable fault. It is probably the wire running to the battery, they tend to take a bit of beating over the years
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
- scubaanders
Re: 82 GPz750 battery warning light
19 Oct 2015 06:19 - 19 Oct 2015 06:20
No new batteries have that electrolyte level sensor, so you can just as well remove the circuit to the sensor.
Just take the pink cable that runs to the sensor, put a fuse holder and a lowest amp fuse you have laying around and connect it to + I strongly recommend a fuse as you otherwise might toast your cluster :S . Leave the sensor in its place with the cable removed.
When done and the warning light will not bother you again, you next battery will probably be a gel bat anyway.
/A
/A
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
Last edit: 19 Oct 2015 06:20 by scubaanders.
- GPzMOD750
19 Oct 2015 07:09 - 19 Oct 2015 07:10
It actually does have the sensor. It supposedly was installed within a year of me buying it. I'll check the levels when I get home.
The next battery will probably be gel or Li-Ion.
Last edit: 19 Oct 2015 07:10 by GPzMOD750.
