are generator covers universal for certain years?
  • lilpeaty
  • lilpeaty's Avatar Topic Author
14 Oct 2015 15:07
#694577
i am looking for a new generator/flywheel outer cover for my 1980 kz750 twin. i found one on ebay and t looks the same but is an 82', obviously am having trouble locating one that doesn't cost my first born since i apparently have an odd duck of a bike.
  • Nessism
  • Nessism's Avatar
Re: are generator covers universal for certain years?
14 Oct 2015 15:23
#694580
Check on your favorite OEM parts site to see if they use the same cover gasket.
  • lilpeaty
14 Oct 2015 15:35
#694583
i have been searching parts sites for a couple of hours with really no luck
  • SWest
  • SWest's Avatar
  • 10 22 2014
14 Oct 2015 15:51
#694586
A pic or two could be helpful. :whistle:
  • TexasKZ
  • TexasKZ's Avatar
14 Oct 2015 15:59
#694588
  • SWest
  • SWest's Avatar
  • 10 22 2014
14 Oct 2015 16:03
#694590
One phase alternator or three?
  • martin_csr
  • martin_csr's Avatar
14 Oct 2015 16:24 - 15 Oct 2015 11:56
#694593
The 82 750-M1 CSR Twin is a chain drive model, so the cover will probably fit. It uses the same gasket.
Any difference is most likely only cosmetic, but I haven't compared them to verify.
Partzilla ->> oem parts -->> Kawasaki -->> motorcycle -->> 1980 -->> KZ750-G1 Ltd-II -->> etc
I'm pretty sure the 750-Twin engine stuff is interchangeable throughout the model range. The belt drive models might vary in regards to the output shaft & stuff related to the mission cover & pulley & that sort of thing.
Last edit: 15 Oct 2015 11:56 by martin_csr.
The following user(s) said Thank You: lilpeaty
  • Nessism
  • Nessism's Avatar
14 Oct 2015 17:10
#694597
lilpeaty wrote: i have been searching parts sites for a couple of hours with really no luck
Look up the gasket part number from a 1980 and then from a 1982. If they are the same part number than you know the covers are most likely going to interchange.
Tell you what, I did it for you and they are in fact the same. I was trying to teach you how to fish instead of giving you a fish.
  • SWest
  • SWest's Avatar
  • 10 22 2014
14 Oct 2015 17:29
#694598
:woohoo:
  • MDZ1rider
  • MDZ1rider's Avatar
15 Oct 2015 10:58
#694659
If you check the parts list, it will also tell you all the bikes that used that exact same part. If yours is a 1980 KZ750E/H1, the generator cover from any of these bikes are a match:
This Kawasaki 14031-1040 COVER,GENERATOR is used on these models and components:
1980 KZ650-E1 LTD ENGINE COVERS
1980 KZ650-F1 ENGINE COVERS
1980 KZ750-E1 ENGINE COVERS ('80 KZY 50-E1)
1980 KZ750-E1 ENGINE COVERS ('81 -'82 KZ750-E2-E3)
1980 KZ750-H1 LTD ENGINE COVERS ('80 H1)
1980 KZ750-H1 LTD ENGINE COVERS (KZ750-H2-H3)
1981 KZ650-H1 CSR ENGINE COVERS ('81-'82 H1-H2)
1981 KZ750-E2 ENGINE COVERS ('80 KZY 50-E1)
1981 KZ750-E2 ENGINE COVERS ('81 -'82 KZ750-E2-E3)
1981 KZ750-H2 LTD ENGINE COVERS ('80 H1)
1981 KZ750-H2 LTD ENGINE COVERS (KZ750-H2-H3)
1982 KZ650-H2 CSR ENGINE COVERS ('81-'82 H1-H2)
1982 KZ750-E3 ENGINE COVERS ('80 KZY 50-E1)
1982 KZ750-E3 ENGINE COVERS ('81 -'82 KZ750-E2-E3)
1982 KZ750-H3 LTD ENGINE COVERS ('80 H1)
1982 KZ750-H3 LTD ENGINE COVERS (KZ750-H2-H3)
1983 KZ650-H3 CSR ENGINE COVERS ('81-'82 H1-H2)
1983 KZ750-H4 LTD ENGINE COVERS ('80 H1)
1983 KZ750-H4 LTD ENGINE COVERS (KZ750-H2-H3)
  • martin_csr
15 Oct 2015 11:54
#694663
His bike is a Twin --- the 1980 model is a 750-G1 Ltd II.
The generator cover & gasket are completely different from the 750-4s. :)
  • lilpeaty
16 Oct 2015 02:32
#694726
Thanks guys, i found the part i needed after looking up a couple of different sites after Nessim said something about OEM sites. Getting that cover off was a real pain. None of the bolts wanted to move at all but we got them all out without stripping any of them. so thank you for all of the help. ;)
