Martek drain on battery?
  • Lmdgr34
  • Lmdgr34's Avatar Topic Author
25 Sep 2015 05:22
#691857
I have a problem of weak spark, engine will not idle under 1100 rpm. The carbs and everything else have already been taken care of which now leads me to my scenario. When the engine is switched on I am only getting 10.12v at the coils with 12.35v at the battery. In my search of tracing out the problem, I checked all the connections even cleaned up the connectors on the on/off switch. Everything is consistently getting only 10.12v....
When I undo the splice connector and remove the red wire to the martek440k and retest the coils instantly have the same voltage as the battery?!
Do these marteks go bad and become drains on the battery?
Would a dyna s ignition solve my problem?
1976 KZ900
29mm smoothbores, pod filters, 4-1 pipe....and a whole lot of daydreaming
  • punisher11b
  • punisher11b's Avatar
Re: Martek drain on battery?
25 Sep 2015 06:35
#691861
If the voltage drops when you start using current that says your battery may be an issue. The potential will most likely read correct with no load on it weather it's good or bad. Although if its going bad the volts will drop once a load is applied. Even just running a headlight. Could be a lot of other things but battery's are easy to have tested and usually for free.
- good luck
  • Lmdgr34
25 Sep 2015 06:50
#691863
The battery is good and I'm sorry for the confusion it is with the switch just on and not the engine running.
If at all possible could someone with a dyna s ignition tell me what their voltage is at the coils and the battery with the key switched on, but not running. That would help me narrow it down to the martek considering I've read some posts on them failing but just not in this particular fashion.
Thanks,
Walt
1976 KZ900
25 Sep 2015 08:03
#691869
I recommend you first check out your charging system; you should find instructions in the Kawasaki Service Manual. If you are only seeing 12.35v at the battery with the engine running something in the charging system is not working properly. I suppose it's possible the battery itself is at fault, but you should be seeing considerable more voltage at the battery with the engine running. Ed
  • Lmdgr34
25 Sep 2015 08:14
#691870
650ed,
I do get considerably higher voltage when the bike is running. It has a brand new stator, battery, rectifier/regulator combo. I have purchased a manual and reviewed what to do for a weak spark. I am trying to avoid doing the "Wire Mod" and rectify the problem. Before the bike is even started but with the key switched on it is showing those low volts at the coils and it is over a 2 volt loss between the coil and the battery. With the cdi unplugged from the splice connector that problem goes away.
Thanks,
Walt
1976 KZ900
  • KZB2 650
  • KZB2 650's Avatar
25 Sep 2015 08:18 - 25 Sep 2015 08:39
#691872
When I got my new Dyna coils and ign 3 years ago I was getting 12.17 and 12.19 from my two with the key on and not running....W/ fully charged new battery.
I can't remember if I had the pick ups hooked or not though and its tore apart right now........ I see your problem goes away with them un hooked so hopefully more will chime in.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 25 Sep 2015 08:39 by KZB2 650.
The following user(s) said Thank You: Lmdgr34
  • LineArtist
  • LineArtist's Avatar
25 Sep 2015 08:33 - 25 Sep 2015 08:37
#691877
Don't all electronic ignitions draw power when the key is turned?
"I have a problem of weak spark, engine will not idle under 1100 rpm"... have you fixed this?
'79 KZ650B3 (stock)
'79 KZ650B3 (parts bike)
'06 HD 883R
Last edit: 25 Sep 2015 08:37 by LineArtist.
  • Lmdgr34
25 Sep 2015 08:56
#691879
Line,
I may be an ass but I'm assuming it isn't idling properly because of the weak spark. As previously stated I've taken care of a lot on this bike I feel this is just the last spot of my problem. Carbs professionally done, new charging system, and maybe you're right that they all do draw some power, I just am unsure that it should be drawing over 2 volts. Apparently these martek cdi's were real popular before dyna came along. Which leads be to believe that it may just be junk.
Thanks,
Walt
1976 KZ900
  • pete greek1
  • pete greek1's Avatar
25 Sep 2015 09:03
#691880
Lmdgr34 wrote: 650ed,
Thanks,
Walt
The Igniter is not needed with Dyna ignition & coils & should be un plugged & removed
Pete
  • SWest
  • SWest's Avatar
  • 10 22 2014
25 Sep 2015 10:06
#691887
From what I've read, they do take a lot of power. The Dyna S does too but not as much. I have a relay for my coils (4ohm) and if my battery isn't fully charged, it will show low voltage like now. It's been a long hot summer and I need to check the water. This just started happening after this trip. Might be low water in the cells. I'll check what the Dyna S pulls later if someone doesn't beat me to it.
  • Lmdgr34
25 Sep 2015 13:50
#691908
OK for sanity sake I plugged it all back together. Started it back up and had it idling around 1k. The volts on the battery read 12.18 and the volts on the coils were 11.45 and 11.43. Normal?
HELP! LOL
1976 KZ900
25 Sep 2015 14:48 - 25 Sep 2015 14:49
#691912
No. I still believe you need to take a look in your manual and see what the voltage at the battery should be with the bike idling. 12.18 v is abnormally low for a bike with the engine running even at idle speed. Trust me on this - the manual will provide the information you need. Ed
Last edit: 25 Sep 2015 14:49 by 650ed.
