Li-ion Battery
15 Sep 2015 06:50 #690145 by Bowman
Li-ion Battery was created by Bowman
Hi, new here so forgive me if this has already been covered but I didnt find much of anything by searching the archives.
Doing a cafe racer style restoration on my 76 KZ750 twin so I'm trying to hide all the electrical bits I can. I'm looking at an Antigravity AG-801 li-ion battery which they say has 240 Crankin g Amps and 9 Ah. Does anyone have any experience with Li-ion batteries in general or specifically this one? I know I need to get an up to date regulator/rectifier. Scecifically will this be enough to use the electric start on a big old twin ?
Thanks
Ken
Honda 55 Trail don't ask me what year, 65? (sold)
79 Yamaha XS400 (sold)
76 KZ750B Twin (project)
72 Honda CT70 (project)
15 Sep 2015 08:44 #690158 by pete greek1
Replied by pete greek1 on topic Li-ion Battery
If you don't already know it, you cant use a regular charger or trickle charger with Li-Ion batteries, you will have to get one that's made for Li-Ion batteries or you will damage the battery
the batteries are about 150.00, & the charger is about 100.00
Pete
The following user(s) said Thank You: Bowman
15 Sep 2015 09:00 - 15 Sep 2015 09:08 #690164 by diggerdanh
Replied by diggerdanh on topic Li-ion Battery
pete greek1 wrote: If you don't already know it, you cant use a regular charger or trickle charger with Li-Ion batteries
That's not entirely true. You can use some regular old trickle chargers on some Li-Ion batteries. My Ballistic battery says that there are a few regular trickle chargers that you can use on it, the Battery Tender Jr. being one and luckily for me the one that I have. But a traditional trickle charger treats the battery as a whole. A charger that monitors each individual cell and evens out the charge across all of them, Ballistic does sell their own - and obviously Ballistic recommends it, is preferred for Li-Ion batteries. That said, I've had my 8-cell Ballistic on my KZ400 for about 2 years now and I've always used just a Battery Tender Jr.
Last edit: 15 Sep 2015 09:08 by diggerdanh. Reason: fixed misspelling
15 Sep 2015 09:50 #690175 by pete greek1
Shorai also recommends not using regular chargers for their Li-Ion batteries, & if you're going to spend 150.00 on a battery, why take a chance on frying it
Pete
15 Sep 2015 11:16 - 15 Sep 2015 11:17 #690193 by Bowman
Replied by Bowman on topic Li-ion Battery
Thanks guys, I'll definately spring for the charger if I go Li-ion. I also hear that Li-ion batteries don't like cold weather but neither do I so I'm safe there.
What I really want to know is if the 8 cell battery has enough grunt to start the bike, goodness knows my 61 year old arthritic right leg doesn't.
Last edit: 15 Sep 2015 11:17 by Bowman. Reason: typo
15 Sep 2015 11:51 #690197 by pete greek1
This is from Shorai wesite
Another important note: Although the Battery Tender is known as a maintenance charger, this is not the case if hooked to a Shorai battery. Because of the voltage differences found in a Lithium battery pack, the charger may not enter "float" or "maintenance" mode. Rather than simply keeping the battery at a proper float level, it may stay in boost mode for long periods. There is then the risk of overcharging the battery, one of the many - See more at: www.batterystuff.com/blog/can-i-use-a-ba...sthash.XBCELpQR.dpuf
Pete
15 Sep 2015 11:59 - 15 Sep 2015 12:00 #690199 by jackleberry
Replied by jackleberry on topic Li-ion Battery
As far as I can tell, these batteries are a bit of a scam. I've built and flown electric RC aircraft using LiPo and Life batteries. It takes great care in charging and discharging not to destroy them (and potentially igniting an inferno).
When I heard of lithium batteries being used in motorcycles I thought, OK, so there must be some special balance charging circuitry built in. The lithium-ion battery packs in your laptop aren't just dumb. They have charging and monitoring circuitry often built into the pack itself.
Anyway, it turns out that even those $300 Shorai lithium batteries are just dumb packs like you'd get if you used an RC lipo. Shorai has a terminal on the battery for balanced charging and sells a charger to connect to it, but this is not meant to be used on the bike. You have to plug the thing into the mains to recharge it. Good luck on your roadtrip...
1997 KZ1000P (P16)
2001 KZ1000P (P20)
Last edit: 15 Sep 2015 12:00 by jackleberry.
15 Sep 2015 13:32 #690207 by spdygon
Replied by spdygon on topic Li-ion Battery
Also u have to make sure your charging system does not charge over 14.4 volts.
Which is the case with the KZ. They can charge up to around 15.5 v.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
15 Sep 2015 14:22 - 15 Sep 2015 16:29 #690215 by pete greek1
spdygon wrote: Also u have to make sure your charging system does not charge over 14.4 volts.
If your charging system is charging at 15.5v. there 's something wrong with it, & you can cook ANY 12v battery, it should charge between 14.2 to 14.5
Pete
Last edit: 15 Sep 2015 16:29 by pete greek1. Reason: want to correct my statement
15 Sep 2015 14:38 #690216 by missionkz
Replied by missionkz on topic Li-ion Battery
A 14L battery is actually a 12v battery..... +15vdc charge rate for any length of time and at any thing more then a couple-few hundred miliamps of current will probably (or eventually) boil the electrolyte mix out of the cells.
I check mine every 3-4 weeks and I am always amazed how for the electrolyte level has dropped.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
15 Sep 2015 14:50 #690217 by Bowman
I love this place already and I've learned a lot in a few short hours and I really appreciate that, thanks everyone. However ... will it start my goddamn scooter? :)
15 Sep 2015 15:00 #690218 by pete greek1
Hell Yea, it'll start your scooter, They're just not recommended for use below 40 degree's , & like you, I gave up riding if It's below 50, many years ago, I've become a fair weather rider in my old age, :laugh: :laugh:
