Installing led tail lights and rear blinkers.
  • Slopar00
  • Slopar00's Avatar Topic Author
24 Aug 2015 18:44
#687035
Hey guys I'm now dipping into lighting on this 83 kz440 ltd and I had a vertical lisence plate mount with built in led tail light and lisence plate light given to me with some led flush mount blinkers. I'm not super great at wiring so any help is great.
Kit came with a black box with 3 wires coming out of it.
Thanks guys and yes I've done some searching but I wasn't sure if the wiring was the same for other bikes
83 kz 440 bobber build. It's my 1st bike/ build I've ever done so it's coming along slow.
  • bountyhunter
  • bountyhunter's Avatar
Re: Installing led tail lights and rear blinkers.
24 Aug 2015 19:54
#687045
what color are the wires?
Do you mean this thing has two separate tail/turn signal lights plus a center license plate light?
If so, that would take three separate power lines plus a ground to operate.
Does the unit ground by the metal frame or does it have a dedicated ground wire?
  • Slopar00
26 Aug 2015 18:34
#687257
Got the new bracket mounted and the light hooked up. Works awesome.
I just need to figure out a place to mount the led rear blinkers.
  • kaw-a-holic
  • kaw-a-holic's Avatar
26 Aug 2015 18:53
#687262
You will also need an LED flasher module if you want the blinkers to work right. I just went to the parts store and told them I needed a 3 prong LED flasher. Plug and play.
SteveW, how easy was it to wire?
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
  • Slopar00
27 Aug 2015 06:13
#687300
Simple. I left all the wires marked so there was no trouble there. The kit came with a small box with 3 wires coming out of it. Is that what your talking about?
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
29 Aug 2015 11:52
#687636
kaw-a-holic wrote: You will also need an LED flasher module if you want the blinkers to work right. I just went to the parts store and told them I needed a 3 prong LED flasher. Plug and play.
Are turn signal/brake LED available to replace our old-style stock bulbs? :)
1982 KZ1100-A2
  • SWest
  • SWest's Avatar
  • 10 22 2014
29 Aug 2015 15:30
#687668
I had a problem with the LED turn signals. Jon sent me his old blinker. It has two blades coming out of the bottom and one ground coming out of the top. I connected the ground to a bolt next to it and had to test switch the blades to make it work. Two tries and " Egore, It's alive!" :evil: My goal was to get my running lights and turn signals to take less power. They do now. Before they were sucking all the juice my charging system could put out. With everything on it was showing 9V and 12V at 4000 RPM. Now it's 12 V at idle and 14 V at 4000. I tried finding one at OR and AZ but the guys just gave me the Fish Eye when I told them what I needed.
  • calegg
  • calegg's Avatar
16 Nov 2015 06:43
#698927
Do you have to get a relay for each bulb or just each direction......... 4 corners or just each side
'81 kz750 LTD - first bike, first project.
