cleaning a starter motor
- gwyon
21 Aug 2015 10:14
1981 kz440 D3
My starter motor doesn't want to spin when it's hot. So I bought a brush repair kit, and I'm taking the motor apart to clean it. I guess I can spray most of the pieces with engine degreaser or carb cleaner. But what's the best way to clean the armature?
Attachment IMG_3309.jpg not found
Attachment IMG_3312.jpg not found
Attachment IMG_3315.jpg not found
1981 KZ440 LTD
- bountyhunter
Re: cleaning a starter motor
21 Aug 2015 11:40
I wouldn't start spraying anything. The coagulated grease can be cleaned off with a small soft brush and some mineral spirits which doesn't attack paint or melt plastic.
The armature: I think I wiped it with a soft cloth wet with mineral spirits to get gunk off. The copper armature where the brush contacts: I got some #600 sandpaper and cut a strip and wrapped it around and turned it by hand. You just want to polish it up until it's shiny.
21 Aug 2015 12:14
You want to clean the gaps. Looks like metal is shorting the armature. I'd use a sharp chisel or screw driver to square them up, then use Emory cloth to clean up the bars.
- undiablo
21 Aug 2015 12:56
Isopropyl alcohol.
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
- gwyon
21 Aug 2015 13:41
Thanks guys. I wiped it down with mineral spirits, a rag, and a soft brush. I polished the commutator with 1000 grit wet/dry sandpaper. It passed the ohmmeter tests. To clean out the gaps, I think I'll use one of those tiny screwdrivers for repairing eyeglasses. Hopefully, it will leave a nice, squared groove. Not sure how to measure the groove depth, though. Service limit is 0.2 mm.
Attachment IMG_3318.jpg not found
Attachment IMG_3322.jpg not found
1981 KZ440 LTD
21 Aug 2015 14:03
Check the bushings. Mine were shot. I had spars so I took the best parts and made one good one.
- MFolks
21 Aug 2015 15:22
A piece of broken hacksaw blade can be used to clean between the commutator areas.
