My starter hates me, I need your help!
- mahamil2
17 Aug 2015 17:42
Hi KZ Rider,
I just bought a used but in great condition 1983 KZ750. Having some starter problems after I got her home. Cold start is a little rough but nothing too crazy. After a couple weeks the bike wouldn't start and made this awful sound. I gave her a push start and she fired right up. Once warmed up it would struggle to start, but would eventually get there after a bit of gas. Yanked the battery and took it up to Autozone, they said it was low so I left it to charge. After putting it back in the bike wasn't completely cooled down but the starter seemed to be working. 2 days later I'm having the same starter issue. Gave it a push start, ran up to Autozone and had them run another load test.... Battery holds the charge fine and has no load problems. I recorded a video so you could hear the sound. This is my first time dealing with a bad starter, from what I've read I'm assuming this noise is due to a bad solenoid, needing a battery with more cranking power, or a bad starter clutch. Please help! I've uploaded a video to youtube of the sound it's making. Just does not seem to engage when its starting.
1983 KZ750F1 Shaft LTD
- retterath
Re: My starter hates me, I need your help!
17 Aug 2015 19:13
Sounds like the starter clutch. I had a kz750 that would miss most of the time, so I just kept trying till it caught. Kind of involved to fix properly.
Welcome to the forum!
17 Aug 2015 19:21
Your starter is fine. As retterath stated, the problem is your starter clutch. The video you posted shows the classic bad starter clutch noise. Do you have a Kawasaki Service Manual for your bike? Ed
- mahamil2
17 Aug 2015 19:34 - 17 Aug 2015 19:35
Thank you for taking a listen. Starter clutch is my worst fear on this one. After running the starter numerous times it hasn't yet caught. Found a service manual online so I guess it is time to start ordering parts and cleaning off the bench.
Last edit: 17 Aug 2015 19:35 by mahamil2.
17 Aug 2015 20:26
Be sure you order ALL the parts including the starter gear. Ed
Attachment StarterClutchGearComparision-5.jpg not found
- Rustyhama
Re: Re:My starter hates me, I need your help!
18 Aug 2015 01:24
Where is the link to your video? I'd like to take a listen to see/hear if I have the same issue. Mine starts fine but makes a pretty horrid metallic screeching sound. I'll have another look in the manual for this starter clutch business.
Hama
'82 KZ305-B1 Cafe Racer
'80 Z750E project
www.dotheton.com/forum/index.php?topic=59260.0
'80 Z750E project
- Rustyhama
18 Aug 2015 01:43
Holy smoke! I think I'll have to live with the noise, at least she starts. The job looks way over my head. Pretty much as soon as I read 'special tool' I throw in the towel. It just get too expensive for me. I have to ship everything from the US, and the exchange rate is real bad now too. It's kinda like kids - 'pick ya battles'
Hama
'80 Z750E project
'80 Z750E project
- KZB2 650
18 Aug 2015 06:00
Please do a search on here ........ its been talked about alot on here with all the part numbers and tools needed .....
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
18 Aug 2015 13:29
Though I like the small fours, the starter clutch being buried inside the cases is a deal breaker for me. That's one of the reasons I sold the 550. Seems a common problem with them.
- missionkz
18 Aug 2015 15:19I wonder if someone could take the used one to a machine shop and have it set up in a lathe and run a mild knurling head on it..??650ed wrote: Be sure you order ALL the parts including the starter gear. Ed
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
