Insturment cluster interchangability?
- Scrapvalue
10 Aug 2015 19:56
Could anyone help me out on which instrument clusters would be the same as the 1981 CSR1000?
My bike has a set of after market gauges and I would really like to take it back to stock.
And if anyone has a set they would be willing to part with, I would be willing to possibly purchase them.
Here is a picture of what is on there now.
Re: Insturment cluster interchangability?
11 Aug 2015 05:51 - 12 Aug 2015 05:43
From the diagrams at partzilla for the 1981 KZ1000-M1 CSR, the speedo & tach seem to be unique to the 1000-M1/M2 models. However, most if not all of the other stuff is the same as the 750M/K (Twin), 750H Ltd & 650H CSR. I'd guess you could use the meters from one of those models, but the red line on the tachometer might be wrong & the warning/indicator lamps may be different. The meter bracket & covers are the same, so the meters should physically interchange. The speedo spins at the same rate on all of them & the tachometers probably spin the same as well.
PS: the 81-82 1000-K Ltd is very similar to the 1000-CSR, but the meter assy is completely different. The Ltd K has electronic meters & the speedo uses a different speedo drive case at the front wheel.
Last edit: 12 Aug 2015 05:43 by martin_csr.
- Tyrell Corp
11 Aug 2015 09:06 - 11 Aug 2015 09:07
Most of these instruments can be interchanged, as above the speedo ratio is the same, but going from cable tachometer to electronic is just taking -ve off one of the coils to feed the black? wire trigger to the tacho.
Going from electronic to cable driven instruments is a problem involves changing the tacho inside the case.
You may likely need to reconfigure the block connectors if swapping between models. Check the wiring diagrams.
Last edit: 11 Aug 2015 09:07 by Tyrell Corp.
- Scrapvalue
11 Aug 2015 13:12
The main thing I am concerned with is that they have the mounting plate and that is fits the stock holes and that they are cable driven.
Figuring the wiring may be somewhat of a pain in the butt, but doable.
11 Aug 2015 14:13 - 12 Aug 2015 05:46
The models I listed have the same meter bracket & just about everything else is the same as well ---- meter covers, dampers, pilot box stuff, etc. You can compare the parts yourself at Kawasaki.com or partzilla. The meters from other 80s models can probably be used, but the ones I mentioned should definitely fit since the other meter stuff is the same.
The 1000-CSR has a fuel gauge in the tachometer. Here's a nice one.
1981 Kawasaki KZ1000 CSR KZ 1000 K480' tachometer tach gauge working NICE!
Last edit: 12 Aug 2015 05:46 by martin_csr.
11 Aug 2015 14:26
I found a couple NOS speedo's for under $100 on eBay.
11 Aug 2015 17:16
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationCorrection, one is used and the other is NOS. Problem is they don't go over 85 mph. Also the bolts are in the 3 and 9:00 position. On the Z1/KZ' they are at 4/10:00. The good sellers have it so there is a slide show where you can see what they look like. Maybe earlier or later years.
