battery not charging during running of bike?
- kzrob
27 Jul 2015 07:52
For some reason..battery checks good..yet after I turn it off..won't start back without a jump
Re: battery not charging during running of bike?
27 Jul 2015 07:58
Turn on everything, then check the voltage and get back to us.
The following user(s) said Thank You: kzrob
- kzrob
27 Jul 2015 09:30
It'll be tomorrow till I can do that.. Out of town right now,and just jumping bike to start it..took battery to auto parts store where I got it..also neutral light has gone out..I'll try this first tomorrow though.
- 76KZ900
01 Aug 2015 22:38
The easiest and first thing to check is battery voltage with bike running. Should be at least 13.8 depending on year of bike.. Newer models usually are closer to that number.. If it's over about 12.5 vdc when running you may have ground issue. If it's closer to 12 likely a stator or regulator issue.
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
76KZ900 (sold) regret
03ZRX1200R (sold) regret
83KZ1100 LTD Shaft
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
