Any Experience with Koso Gauges?
  • rctreadaway
  • rctreadaway's Avatar Topic Author
16 Jul 2015 10:37
#681130
I have the Koso T&T Multi Gauge and overall I'm very happy with it. Seems well made and all the info i need is in one compact spot. But I'm having an issue with the tach bouncing around some. It's currently hooked to the ring terminal on one of the Dyna coils. I'm curious if hooking to both would help any?
1980 KZ1000 LTD -
CR Special Carbs/Kerker Exhaust/K&N Pods/Dyna Ign
'09 ZX6R Controls/Rearsets
'06 GSXR1000 Suspension (to be installed)
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Any Experience with Koso Gauges?
16 Jul 2015 10:42
#681133
Pics?
  • rctreadaway
16 Jul 2015 11:36
#681137
Horrible picture but it's the only thing I had on my phone. Had snapped a few quick pictures before I dropped it off to have some carb adjustments made.
1980 KZ1000 LTD -
  • 80B4
  • 80B4's Avatar
16 Jul 2015 18:32
#681180
I used a Koso on an ST 1300 fighter nine years ago, high quality and easy to install. Check your ground wire.
1980B4 1000
1978 Z1R
1978 B3 750
  • rctreadaway
16 Jul 2015 19:49
#681204
I tied the ground into black/yellow in the headlight bucket where my other connections are. I'll try grounding straight to frame and see how it does. Hope to get my bike back this weekend. Thanks
1980 KZ1000 LTD -
  • 80B4
  • 80B4's Avatar
17 Jul 2015 07:48
#681316
The ground circuit is always marginal on our classic bikes. I always build my own. 12 guage wire and directly back to the ground point of the battery. I then feed all of the major grounds back through it. The headlight, horn, taillight and ignition. Everything works better.
1980B4 1000
1978 Z1R
1978 B3 750
The following user(s) said Thank You: rctreadaway
  • rctreadaway
17 Jul 2015 09:48
#681352
Yeah I've been going through the wiring redoing things here and there just to clean it up and get it more reliable for the summer. I plan on redoing it all this winter so I'll end up doing something along those lines. Really want to lean it up and switch to deutsch connectors for simplicity sake. Appreciate the input. I'll definitely redo the ground to see how it acts.
1980 KZ1000 LTD -
