battery too weak?
  • blink543
  • blink543's Avatar Topic Author
battery too weak?
14 Jul 2015 14:04
#680834
I hooked up my 1978 kz650b electric starter and the starter barely turns. I did a battery test the other day and it said the battery is good. So why is the starter having a hard time turning? Its a wet cell battery.
Adam james
  • zero10
  • zero10's Avatar
Re: battery too weak?
14 Jul 2015 14:06
#680836
What is the battery voltage before and while cranking?
  • SWest
  • SWest's Avatar
  • 10 22 2014
14 Jul 2015 14:42
#680846
If your battery is or is going bad, it can destroy your electrical system.
14 Jul 2015 14:46 - 14 Jul 2015 14:46
#680849
If the battery is bad replace it; if it needs to be charged disconnect it from the bike and charge it at LOW amperage (2 amps or LESS). Do NOT try to start your bike with a battery charger hooked up to it or by using jumper cables that are attached to a running vehicle as that can cause problems with your bike's electrical system. Ed
Last edit: 14 Jul 2015 14:46 by 650ed.
  • blink543
14 Jul 2015 14:49
#680850
Before 11.3 while cranking dipping to 5
Adam james
  • Irish Yobbo
  • Irish Yobbo's Avatar
14 Jul 2015 16:17
#680856
11.3V? Battery is cactus. You can try charging it (low amperage as stated above - if you use a high amperage car charger it can boil it).
11.3V indicates that the battery is at about 10% charge. Might be past the point of no return, depending on how long it's been that way for.
You can jump a motorbike from a car, but best not start the car like you would if you are jumping another car. You don't need the extra starting voltage - just jump from the battery alone.
1981 KZ750 LTD
  • SWest
  • SWest's Avatar
  • 10 22 2014
14 Jul 2015 16:49
#680863
Get a battery. I get my batteries from High Tech Battery Solutions on line. Under $50 delivered with a one year warranty. AZ and others have a 90 day only.
  • bountyhunter
  • bountyhunter's Avatar
14 Jul 2015 16:50
#680864
Make sure the battery is charged. You can get a cheap charger from Harbor Freight.
  • blink543
14 Jul 2015 19:44
#680903
Yeah I'm going to look around for a new battery
Adam james
  • SWest
  • SWest's Avatar
  • 10 22 2014
14 Jul 2015 21:27
#680922
Not the numbers 12N etc.
  • missionkz
  • missionkz's Avatar
14 Jul 2015 22:06
#680925
And make sure it comes with a bottle of acid.... some DO NOT!!
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • blink543
15 Jul 2015 04:02
#680937
What do the battery numbers mean? I'm having a hard time finding one that fits the battery holder. Went to AutoZone and they didn't have a battery that fit.
Adam james
