turn signal relay for 1978 kz650b
- blink543
13 Jul 2015 11:07
So my turn signal relay burned out. I've seen on Amazon the same looking type of relay but it was blue and said it's for LEDs. All of them were basically LED relays. Can I use them for incandescent bulbs?
Adam james
Re: turn signal relay for 1978 kz650b
13 Jul 2015 11:23
I use a Tridon/Stant 552 2 prong relay on my KZ650. It works perfectly for incandescent bulbs. In fact, It works better than stock because it is electronic. As a result, the blinkers flash at the same rate even if the battery is a little low. It is an exact plug and play replacement that fits perfectly in the same holder as the stock relay and used the same connections. They are not expensive and are available at auto parts stores; I bought mine at Advance Auto. Ed
- blink543
13 Jul 2015 11:33650ed wrote: I use a Tridon/Stant 552 2 prong relay on my KZ650. It works perfectly for incandescent bulbs. In fact, It uworks better than stock because it is electronic. As a result, the blinkers flash at the same rate even if the battery is a little low. It is an exact plug and play replacement that fits perfectly in the same holder as the stock relay and used the same connections. They are not expensive and are available at auto parts stores; I bought mine at Advance Auto. Ed
Thanks ed I'll go look today
Adam james
- Irish Yobbo
13 Jul 2015 16:36
The LED Relays are better in every way. Just make sure it can handle the current - the relay should have a max (and maybe a minimum) current for operation.
1981 KZ750 LTD
