78 kz400 c1 Headlight Assembly
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: 78 kz400 c1 Headlight Assembly
09 Jul 2015 07:23
#680158
Single phase or three phase alternator?
  • Drafter89
  • Drafter89's Avatar Topic Author
09 Jul 2015 07:34 - 09 Jul 2015 07:35
#680161
Hey Steve... I believe its a Dynamo.
Single phase A.C
swest wrote: Single phase or three phase alternator?
78 KZ 400 C1-Daily Driver
New Albany,IN
Last edit: 09 Jul 2015 07:35 by Drafter89.
  • SWest
  • SWest's Avatar
  • 10 22 2014
09 Jul 2015 07:43
#680163
That limits how much you can do. LED conversion?
  • Drafter89
09 Jul 2015 07:47
#680165
Are you asking have I converted or should I?
swest wrote: That limits how much you can do. LED conversion?
New Albany,IN
  • SWest
  • SWest's Avatar
  • 10 22 2014
09 Jul 2015 08:16
#680171
It was a suggestion.
  • Drafter89
09 Jul 2015 08:29
#680176
Ok. Thanks bud. I'll look into it
New Albany,IN
  • martin_csr
  • martin_csr's Avatar
09 Jul 2015 14:00 - 09 Jul 2015 14:01
#680207
I mentioned the wattage because some models had a lower watt headlight --- I think yours is 35W. I don't know if a higher wattage headlight would tax the wiring or charging system or what. If the stock sealed beam is 60/55W, then the H4 should work no problem.
My 81 KZ650 came stock w a 60/55W sealed beam & I installed an H4 headlight from a KZ750. I think there's a 100W H4 available, but it would draw too much power for the wiring.
Last edit: 09 Jul 2015 14:01 by martin_csr.
09 Jul 2015 14:23
#680211
Yes there is a 100we H4 bulb, I used one for a year or so. And yes, it did fry one of my connectors and it also burned the silvering inside the Marchal lens. It sure was bright though; the box said it was for offroad use only and was not legal for the street. :ohmy: I do not recommend it. Ed
  • SWest
  • SWest's Avatar
  • 10 22 2014
09 Jul 2015 21:38
#680275
I had a Marchal with a pencil beam in the bottom. People would flash their high beams at me until I flipped on the high beam. That nonsense would stop immediately. :evil: Bulbs were getting too hard to get so I went with a halogen.
