78 kz400 c1 Headlight Assembly
  • Drafter89
  • Drafter89's Avatar Topic Author
06 Jul 2015 06:25
#679618
Ok This has me flustered! Went to replace my headlight bulb in this thing and It looks like you cant just replace the bulb..you have to replace the whole thing besides the outer hub thingy. Ive had other kz's that were not like this. The manual sais to just replace the bulb and there is absolutely no way. Im stumped. Is it supposed to be like this?
78 KZ 400 C1-Daily Driver
New Albany,IN
  • martin_csr
  • martin_csr's Avatar
Re: 78 kz400 c1 Headlight Assembly
06 Jul 2015 07:24 - 06 Jul 2015 07:24
#679630
I'm not familiar with the KZ400 headlight. Did you get the correct headlight sealed beam unit?
NOS Kawasaki KZ400 KZ440 Headlamp Unit Lens 23007-059
For comparison only. Notice that this one doesn't have mounting tabs on it.
KAWASAKI HEADLIGHT HEAD LIGHT LENS KZ1000 KZ750 LTD CSR NOS/OEM 23007-1006
Last edit: 06 Jul 2015 07:24 by martin_csr.
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
07 Jul 2015 04:15
#679863
I had the same problem with my 76 KZ400. I could not find a bulb to fit the headlight shell. I ended up going to an aftermarket shell with an H4 bulb. It is an Emgo unit and looks stock to the untrained eye.
[IMG
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
The following user(s) said Thank You: Drafter89
  • Drafter89
09 Jul 2015 05:04 - 09 Jul 2015 05:06
#680131
That first link is the exact same one I have. and no I havent. I just purchased the bike and im going through and trying to replace what needs to be replaced. But looks to me Im going to have to buy that whole thing :( They look quite expensive
martin_csr wrote: I'm not familiar with the KZ400 headlight. Did you get the correct headlight sealed beam unit?
New Albany,IN
Last edit: 09 Jul 2015 05:06 by Drafter89.
  • Drafter89
09 Jul 2015 05:09
#680132
Sweet man! I might have to go with something like this. How much did this cost you if you dont mind me asking?
ThatGPzGuy wrote: I had the same problem with my 76 KZ400. I could not find a bulb to fit the headlight shell. I ended up going to an aftermarket shell with an H4 bulb. It is an Emgo unit and looks stock to the untrained eye.
New Albany,IN
  • TexasKZ
  • TexasKZ's Avatar
09 Jul 2015 05:36
#680134
  • Drafter89
09 Jul 2015 05:46
#680135
Thanks Tex!
New Albany,IN
  • martin_csr
09 Jul 2015 05:54 - 09 Jul 2015 05:58
#680137
Z1Enterprises.com has Emgo headlight buckets, but I'm not sure if they're the same type as in gpzguy's pic.
H4 lens unit set. appears similar to stock. pricy but others are listed. H4 Upgrade Universal 6-3/8 Inch .
I do not know if your bike can use a 60/55W H4 bulb. eebbaayy search = KZ400 headlight
Last edit: 09 Jul 2015 05:58 by martin_csr.
  • TexasKZ
  • TexasKZ's Avatar
09 Jul 2015 05:58
#680138
Still listed by Kawasaki, so it could be getable at a dealer, too.
www.kawasaki.com/Parts/PartsDiagram/142668/1978/KZ400-C1
  • Drafter89
09 Jul 2015 06:27
#680148
Martin..Why wouldnt my bike be able to run a 60/55w h4 bulb? Sorry im somewhat cluless when it comes to electrical :(
New Albany,IN
  • SWest
  • SWest's Avatar
  • 10 22 2014
09 Jul 2015 07:01
#680153
It depends on the charging system.
  • Drafter89
09 Jul 2015 07:15
#680156
Figured it was something along those lines lol
New Albany,IN
